Plug & Play EMS for Caldina GT-T
Postby CaldinaGt_t » Mon Oct 02, 2006 5:35 am
which ones are available for it and how do i go about getting one for my car?
3SGTE POWER RULES!
2000 Caldina GT-T
TD05-BIG16g,o2 housing wid external dump pipe, front mount intercooler, speed limiter removed, 1jz-gtte pistons, and lots of boost
CaldinaGt_t
Postby Adydas » Mon Oct 02, 2006 9:06 am
i think the short answer is " NONE " and " So you cant "..
Adydas
Postby CaldinaGt_t » Mon Oct 02, 2006 5:06 pm
why none?
3SGTE POWER RULES!
2000 Caldina GT-T
CaldinaGt_t
Postby atmosports » Mon Oct 02, 2006 5:33 pm
To the best of my knowledge I don't think there is anything, though I must admit I haven't looked that hard. I am saying this as we've done quite a few now as wire-in installations running either Haltech, or Link Ecu's, I'm sure that if there was an easily available plug & play setup that was of use, these guys who we did wire-ins for would've gone the plug & play route. In saying that you could always match up the ecu header socket & get another one & use this to make an adaptor loom from whatever ecu you wanted to back to the stock loom, that way it would just be a matter of sorting out the ecu configuration, I've done this with both ep82/91 starlets & a few other cars that plug & play units are easily available for(sure AP engineering make them, but who has got 3-6months to wait for a new one)
atmosports
Postby fivebob » Wed Oct 04, 2006 4:57 pm
There are several ECUs available from Japan that are plug and play, but getting English software to tune them is next to impossible.
It's easy enough to make a plug and play adapter loom for most of the aftermarket ECUs, provided they can share ignition signals, the Auto ECU shouldn't have any problems with shifting. The manual ECU could be eliminated altogether.
Another option is using a piggy back unit like the Greddy E-Manage or the HKS F-ConS.
