funny shudering when breaking from the passengers front
Postby SkunkWeRX » Mon Oct 02, 2006 9:39 pm
ae92 wagon
hey guys any idea,ive been thinking it may be the disc is warped on the passenger side?
only notice the shudering when the breaks applied?
any suggestions as any thing else that may cause this?
SkunkWeRX
Postby hsmidy » Mon Oct 02, 2006 9:49 pm
does ya brake pedal pulse back at ya when braking? good indication ya discs are warpd
hsmidy
Postby Stealer Of Souls » Tue Oct 03, 2006 8:18 am
Warped or uneven deposits of brake material.
Read an article a little while back that explained a lot of "warped rotors" are in fact not warp. When you brake a thin layer of brake material gets deposited on the rotor, and this thing layer of brake material helps increase brake performance, but an uneven layer can cause the shuddering as the brake pads slide from the slightly grippier areas to non-grippy areas of the rotor.
I will see if I can locate the article. It was online somewhere.
Anyway. Try this before getting skimming. Go somewhere nice and safe (I find road to Piha at night is a useful place) and then proceed to try and make your brakes fade as bad as possible.
This has worked for me. After trying to fade the brakes (mintex pads just don't fade that well on an ae86) most of my shudder disappeared. Unfortunately one of my discs wasn't true either... so had to get a skim anyway...
'86 AE85.5 Levin
Stealer Of Souls
Postby SkunkWeRX » Tue Oct 03, 2006 12:43 pm
hey thanks for the replies i have another set of break laying around so i mite try changing the disc and see if it makes it stop .other wise i'll try changing the whole set up.
yeah you can feel it in the pedel to.
SkunkWeRX
Postby B1NZ » Tue Oct 03, 2006 5:17 pm
hsmidy wrote:does ya brake pedal pulse back at ya when braking? good indication ya discs are warpd
or you have ABS :lol:
Warped discs seem to be the most likly outcome here i would think, I know it sounds stupid, but have you made sure your wheel is the correct size and is on properly?
Possibly need balancing?
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby SkunkWeRX » Tue Oct 03, 2006 6:40 pm
yeah ive just got 13" rims just little mags on it .
and ive tried rotating them aswell.
i'll swap the disc out with a spare that i have.
SkunkWeRX
Postby Jazza » Tue Oct 03, 2006 9:46 pm
Your nuts tight? :lol: Wheel nuts of course
1996 Curren - On Tardme
1992.5 EG Civic - 101kw@wheels. WTB 4x100 6.5in wide rims.
Jazza
