VVT point in 20v Silvertop
Postby Mr Revhead » Sat Sep 23, 2006 9:15 am
refer to the graph above..... vvt does activate below 2000 rpm in silvertops.
i personally tested it on my car
Postby sergei » Sat Sep 23, 2006 10:01 am
I can get my silvertop to activate VVT just by taping on the throttle while on idle (I got one of those ga'y lights in same place as GTZ light which I installed when I was younger ;) )
Postby Mr Revhead » Sat Sep 23, 2006 10:06 am
lol i put one in when i was comparing the stock ecu to my SARD one.
took it out as soon as i was finished. i used a park lamp bulb and it was too bloody bright! :lol:
Postby AceSniper » Sat Sep 23, 2006 11:53 am
hmm im sure it was lower than 2k, maybe I was idling high :lol:
AceSniper
Postby slighty_sykotic » Mon Sep 25, 2006 12:12 am
And 12 BTDC of timing would be causing the motor to ping its nuts off on our fuel....making the motor retard the hell out of it, hence why its sluggish at high rpm.
--Sykotic
slighty_sykotic
Postby mister2 » Thu Sep 28, 2006 2:02 pm
There are a few myths around VVT, especially to do with equating it with VTEC. Most have been addressed in this thread, but just to add my own 2c.
VVT (in 20v's) is a switched output which changes the intake cam timing by a fixed amount. When the cam is ADVANCED (on) the engine will make more power from idle RIGHT THROUGH to around 6-7000rpm. With the cam RETARDED (off) it will make more power above 6-7000rpm, and will idle smoothly.
So essentially, the only reason that VVT is off at idle and low load is for emissions, idle quality, and economy. And it switches off at high RPM because that is where the off position makes the most power.
It is pretty easy to see on a dyno, doing plots with and without VVT.
What this means though is that it is slightly more complex to think about than VTEC, where on = woohoo! You need a ECU capable of mapping the VVT output, not only a RPM-switch.
Nick
www.nzefi.com
4WD Dynapack Dynamometer.
Link, MoTeC, Greddy, Power FC sales support and tuning.
Weapon of Choice: 1992 NSR250 SE
On hiatus, current location: Cambridge, UK
mister2
Postby Loudtoy » Thu Sep 28, 2006 9:48 pm
You may also want to try freeing up your intake and exhaust as much as possible, i found on my old facelift 101 that the less intake and exhaust restrictions i had the more power i had especially up top. Also 12btdc is far to advanced for our fuel as someone had said. Best i've found is about half that. PS if you've got a standard exhaust leave it on there get rid of the cat only and just do the intake, the standard exhaust is probably imho the best flowing and quietest sysytem for these cars.
Oh and about the vvt, if you want to feel what kind of difference it makes with it on and off you can just unplug the vvt solenoid for a short time it's down on the front side of the block on the pully side. Try it with it unplugged and see what difference it makes
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby quicklvn » Fri Sep 29, 2006 9:41 am
Cheers guys, I feel like a n00b now :oops: lol, I don't know too much about the workings of the cams etc.
My car has a 2 1/4 freeflow on and a pod filter so thats the restrictions gone (hopefully).
I'm planning on getting it dynoed once I put my oil catch can on and an adjustable fuel pressure reg to see what they pick up. My mates also building a diognostic computer device to pick up engine faults so i'll see what that picks up.
thanks for the help
quicklvn
Postby Mr Revhead » Fri Sep 29, 2006 9:49 am
20vs seem to like having the stock air box rather than a pod.
fit a K&N filter into the stock box.
adjustable fuel reg is not needed, your just wasting your $$ there and opening a door way for potential problems.
Postby Loudtoy » Fri Sep 29, 2006 7:42 pm
Mr Revhead wrote:20vs seem to like having the stock air box rather than a pod.
I disagree with the statement about the pod, so long as you do it properly and build a proper cold air box around it, have the intake pipe about 3 inch and nice madrel bend of 90 degrees leaving the pod right up behind the headlight. Will require turning the airflow meter upside down so the wires will reach and works a hell of alot better than a k&n in the standard box - about 6kw difference in my experience and thats with an el cheapo pod from a k&n panel.
Oh yeah the possible downside is you will need to move your battery to somewhere else to make room for you intake.
TS Member sine 2001
Loudtoy
Postby Mr Revhead » Fri Sep 29, 2006 7:49 pm
iv heard of blacktops mking a gain with open/pod filter
yours would be the first time iv heard of a gain on a silvertop
Postby Loudtoy » Mon Oct 02, 2006 8:16 pm
Mr Revhead wrote:iv heard of blacktops mking a gain with open/pod filter
Fair to say i had a freak one, exhaust and intake only (mind you was all my own design stuff) made 84 kw sock, 87 with exhaust and standard intake and 93 with intake and exhaust. All same dyno but different days, 93 was mid summer 84 was mid winter and 87 was somewhere in the middle. Sold the car and dyno sheets went with it as the guy who brought it mates wouldn't believe that my 101 would make slightly more than his 111 on the same dyno lol. If i still had them i could have told you the temp exactly :?
TS Member sine 2001
Loudtoy
Postby vvtirep » Mon Oct 02, 2006 10:21 pm
if you want more power top end you could get some extractors. thats if you want to pay that price???
Tim Taylor
vvtirep
Postby Mr Revhead » Mon Oct 02, 2006 10:35 pm
youll be lucky to find some that are better than the stock ones
change the 2-1 section if anything
Postby quicklvn » Tue Oct 03, 2006 8:20 am
Yeh, I was gonna buy some yesterday but I've just heard they have sold. Would it be best to get the 2-1 section of a blacktop or custom? and how will I have to modify it to make it better?
quicklvn
Postby AceSniper » Tue Oct 03, 2006 12:16 pm
custom
blacktop still has the squish init, but has another flexi setup (thats also used in facelift 101's)
AceSniper
Users browsing this forum: No registered users and 26 guests
