4agze Turbo Questions
Postby Bazda » Sun Oct 08, 2006 10:11 pm
True-No-Turbo wrote:
z0ton wrote:So you reckon a wastegate like this would be alright?
http://www.trademe.co.nz/Trade-Me-Motor ... 153604.htm
And a BOV like this?
http://www.trademe.co.nz/Trade-Me-Motor ... 742967.htm
cant vouch for either but they seem to fairly good quality, as long as the diaphram and valve are made from the same materials as the well known brands they should be fairly decent.
any bov should do bar ssq copys, I went with the tial 50mm because a couple of guys here used them and they seem to hold well on high boost..
27psi of high boost!!
Postby z0ton » Mon Oct 09, 2006 7:32 am
So is the size of the wastegate you use relative to how much boost you run then? Im only gunna be running 12 or so so 38mm will be fine?
And I found some piping on trademe.
http://www.trademe.co.nz/Browse/Listing ... d=72742953
Not sure how the price competes with tube bending etc though.
z0ton
Postby bluemaumau » Mon Oct 09, 2006 9:42 am
i remember reading something (it was in nzpc however)
low boost - big turbo = big wastegate
low boost - small turbo = big wastegate
high boost - big turbo = small wastegate
high boost - small turbo = small wastegate
Postby EVLGTZ » Mon Oct 09, 2006 10:09 am
bluemaumau wrote:i remember reading something (it was in nzpc however)
didnt ya just say the same thing twice?
I do remember reading that somewhere but not sure how correct it was and also think there was
low boost - small turbo = small wastegate
high boost - big turbo = big wastegate
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby bluemaumau » Mon Oct 09, 2006 10:39 am
haha edited :oops:
Postby z0ton » Mon Oct 09, 2006 5:47 pm
Seriously im sure that doesnt make sense... Can anyone recommend what size wastegate to use with a T3/T4 running around 10-12psi??
z0ton
Postby bluemaumau » Mon Oct 09, 2006 5:52 pm
according to nzpc big wastegate :D
Postby Bazda » Mon Oct 09, 2006 5:52 pm
z0ton wrote:Seriously im sure that doesnt make sense... Can anyone recommend what size wastegate to use with a T3/T4 running around 10-12psi??
just run a 38mm its the most common size to buy.
Postby Crucible » Mon Oct 09, 2006 5:54 pm
A 38mm gate will be fine, others here use the same size gate with t3/4s
Im running a gen Tial 38mm one and T3/4, holds boost fine, no problemo
Crucible
Real Life Mechanic
Postby flygt4 » Mon Oct 09, 2006 6:02 pm
get a standy one off an audi quattro :wink: 38mm standard and no issues at 20psi :) stupid cracksmoking germans
flygt4
Postby themaleman » Mon Oct 09, 2006 7:13 pm
this may be of some help. the turbo is infront of the engine, not beside or above it
viewtopic.php?t=50583
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby Bazda » Mon Oct 09, 2006 7:39 pm
themaleman wrote:this may be of some help. the turbo is infront of the engine, not beside or above it
??? the turbo has been low mounted.
Postby themaleman » Mon Oct 09, 2006 8:05 pm
haha good spoting :P
4agte ae92 Levin
a15 powered sj410
themaleman
Postby Crucible » Mon Oct 09, 2006 10:10 pm
So when do we get our own 4agte section ??
If you want a reply to a thread just type in 4agte somewhere in the title and its guaranteed to get swamped everytime :D
Crucible
Real Life Mechanic
Postby trdfxgt » Tue Oct 10, 2006 5:23 pm
mines 40 mm small turbo works fine a wastegate is a wastegate unless its rediculusly big
trdfxgt
Postby z0ton » Sat Oct 28, 2006 10:20 pm
Ive decided im gunna leave it supercharged for now. But I still have a few questions. Im putting the engine into a corolla with a 4afe.. And I have a 4agze box and axles and im wondering what im gunna need to change to make the axles fit?
Ive been told I need to upgrade my radiator too? Heres mine now:
z0ton
Postby z0ton » Mon Oct 30, 2006 5:31 pm
Anyone? :!:
z0ton
Postby Bazda » Mon Oct 30, 2006 5:42 pm
to make the axles fit you will need the 4agze hubs.
radiator will be more than enough, we usually put smaller ones on when going turbo, only because of space but they still work fine.
Postby bluemaumau » Mon Oct 30, 2006 8:07 pm
im pretty sure that all ae models have the same spline, im running gt-apex hubs on gze shafts.
Postby z0ton » Mon Oct 30, 2006 8:15 pm
bluemaumau wrote:im pretty sure that all ae models have the same spline, im running gt-apex hubs on gze shafts.
I will soon find out. All I know is these axles look a hell of a lot bigger than mine at the moment...
z0ton
