ok bout 5mins ago one of the guys i work next to said he can get me a 3tgte for bout $600 with loom and ecu.
has any1 put one of these in a kp60 and is it a mojor?
also would like to know if there are any pro's and con's with that motor
thanks
Mmm, Boost wrote:Yeah but timing chain tensioners, pistons and bearings are. As long as its in good nick it'll be fine.
itsamirage wrote:You might want to increase the wheel base tho (not as hard as it seems) will give you alot more control.
