AE92 BLOWER FAN NOT WORKING
Postby B1NZ » Mon Oct 09, 2006 9:24 pm
The demister fan on my Ae92 FXGT is intermittant, It has only ever worked on the 2 fastest speeds since I've owned it, and recently has been stopping altogether, any help greatly appreciated :-)
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby Alex B » Mon Oct 09, 2006 9:32 pm
Not even work of full? Could be a $&#$% resistor pack.
Postby Santa'sBoostinSleigh » Mon Oct 09, 2006 10:20 pm
my integra one filled up with water and hence stopped working
check its not full of water
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby B1NZ » Tue Oct 10, 2006 7:22 am
pyro_sniper2002 wrote:Not even work of full? Could be a $&#$% resistor pack.
Im confused by the wording of your qusetion, please repeat?
Subaru GF8 Wagon
B1NZ
Postby solitaire » Tue Oct 10, 2006 4:17 pm
whats the electrical thing that varies voltage etc? solenoid or somthing?
either way im pretty sure if it has reduced to having a "on or off" rather than "off, 1, 2, 3, full on" thing then its just the little thingy that controls the voltage...
sorry i know i sound like a complete idiot but im pretty sure im right...
AE92, KZJ120, KDJ120
solitaire
Postby malc » Tue Oct 10, 2006 5:25 pm
interesting , the fan in my ae92 only works on the 2 fastest speeds also
slightly annoying but I just put up with it
malc
Postby B1NZ » Tue Oct 10, 2006 5:27 pm
Razz wrote:interesting , the fan in my ae92 only works on the 2 fastest speeds also
I have been until now, It gets real aanoying when it works on the way to a motorsport event, then when it comes time for scrutineering they wont let you race, (although they did last time)
Subaru GF8 Wagon
B1NZ
blower fan
Postby catchafox » Tue Oct 10, 2006 5:37 pm
under the passangers side foot well, behind the glove box is a small box which is your resistor pack that controlls the fan speeds. It is after the blower fan and before the heater box (normally in the a/c evaporator box).Generally held in with 2 screws and will have 4 or 5 thick wires going to it.You will know when its the right one as when you remove it it will have a large alloy heat sink which is cooled by the air flow.Take it to the reckers or your local dealer cough up a wad of cash wack it back it and your sorted.
catchafox
Postby B1NZ » Wed Oct 11, 2006 8:53 pm
spank you, I thought that may be the problem, I'll give it a crack and let you know :-) I think I've got a spare one lying around somewhere
Subaru GF8 Wagon
B1NZ
