How to fix broken rear crank shaft bearing...
Postby MOLLY » Tue Oct 24, 2006 7:40 pm
where the gearbox goes into the engine, on a 4k, can the bearing be replaced or does it require parts of the engine to come off?
Thanks
MOLLY
Postby bluemaumau » Tue Oct 24, 2006 8:03 pm
in the box or engine?
Postby MOLLY » Tue Oct 24, 2006 8:07 pm
In the engine, where the crank shaft rear oil seal is.
MOLLY
Postby Lloyd » Tue Oct 24, 2006 8:10 pm
Can replace it, assuming you mean the spigot bearing that presses into the flywheel. Easiest way is to take the flywheel off and bash it out with a hammer and punch/screwdriver/whatever. Just tap the new one back in to the same place. New ones are only like $6 or something stupidly cheap.
Postby MOLLY » Tue Oct 24, 2006 8:11 pm
Yes it sits in the flywheel
Thanks
MOLLY
Postby l1ttle_d3vil » Tue Oct 24, 2006 8:14 pm
yep definitely replaceable, i replaced mine the other day. simple job.
Postby matt dunn » Tue Oct 24, 2006 11:38 pm
MOLLY wrote:Yes it sits in the flywheel
Thanks
Um, they are actually in the end of the crank so removing the flywheel does nothing does it?
Matt
