TEMS- Technical Info wanted
Postby Timmo » Tue Oct 24, 2006 6:21 pm
Hi all- With all the hoo-haa ive been reading about the new VE Commodore, one of the selling points is its 'magna ride' (i think that is it) suspension.....my first reponse was 'Toyota had that 20 years ago!' but i want to get my facts straight first before I yell it to the world
Now, TEMS was released many a year ago by Toyota (1983 was the first application in the Soarer?) and im trying to find out how exactly it works....I assume it either is similar to the VE system (iron impregnated fluid which increases its viscosity when a magnetic field is applied thereby increasing damping) or possibly just constricts a valve thereby reducing the flow of fluid (and increases damping)
Ive sifted through a heap of stuff returned by google and also searched this MB but havent found a definitive description on diagrams on how it works. The only reference that looks like it may give an answer would require me to pay $$ (SAE site)
I used to have it on my Jzz30 Soarer: You could certainly feel a difference but it wasnt huge......I just want some 'Toyota did it 20 years ago' ammo to take those Ford/Holden supporters ;)
(Similar to Mercedes' 'Cutting Edge' active suspension released a year or two ago....Toyota had active suspension on the 1991 Uzz32 Soarer, Infinity had it before that)
Has anyone got access to techinical articles of this nature.....or better at sifting through google resuslts?
Lightweight baby
1991 MX5 Supercharged
Timmo
Postby Mr.Phreak » Tue Oct 24, 2006 6:25 pm
Or maybe it's better to not start a "My Dad is better than your Dad" arguement and just enjoy Toyotas.
If you convince everyone that they're better, all you'll do is push up Toyota prices :P
Mr.Phreak
Postby Timmo » Tue Oct 24, 2006 6:46 pm
found this....I need a diagram to get my head around it though:
START
Vibration damping can be achieved by mechanical impedance coupling or the superposition of out-of-phase antivibrations. A passively damped system's response is fixed and, therefore, represents a compromise at all but one, or at most a few, rates of energy input. Adaptive systems slowly adjust, or require manually set damping (impedance) characteristics, to accommodate a broader range of input situations.
Semiactive systems make such damping adjustments automatically, in several tens of a millisecond response times. Passive and semiactive systems are energy absorbing, whereas active systems input energy to a system. Active approaches are complex and energy-demanding processes that restore a system to its desired state or position. In automobiles, the feel of active systems can be closely approximated by semiactive means at much lower cost.
The basic elements of any automotive suspension system (viscoelastic engine mounts, springs, shock absorbers, and tires) are part of a complex vibration and acoustics system. Traditional passive suspension systems are evolving to adaptive, semiactive, and active control systems. Suspension dynamics, for comfort, performance and safety, can be controlled in real time. Active and semiactive control systems are based on inputs of accelerations, steering angle, road conditions, tire deflection, relative positions of wheels and body, traction, etc. Ceramic sensor demand will exceed that for actuators.
High-speed piezoceramic valve actuators were introduced by Toyota (Aichi, Japan) (1983 TEMS, Toyota Electronically Modulated Suspension) to achieve a broad range of damping forces via the semiactive control of shock absorbers. A PZT sensor stack, colinear with a larger actuator stack, provided the system with a control signal that indicated vertical motion. Atsugi Unisia (Japan) introduced a completely active hydraulically pumped system at about the same time. Each suffered from high cost, but the latter in particular suffered from high weight and power consumption with adverse affects on fuel economy.
More recent active approaches involve composite springs, PZT or magnetostrictive motor and suspension mounts, and engine performance controls, such as PZT knock sensors. System simplicity and integration cost will be the prime factors in determining which ceramics-based approaches are accepted. Ceramics will face stiff competition from magnetostrictive actuators and electromechanical, pneumatic or hydraulic systems in actuator applications.
END
It also mentions Toyotas 'Active' Suspension....such an amazing system but just too expensive: I would love to go for a blast in a Uzz32 'Active' Soarer one day
Lightweight baby
Timmo
Postby Caveman » Wed Oct 25, 2006 9:40 am
hey good find
interesting read 8)
AW11 Track Toy
Formerly known as 1998
Caveman
