Rotary Owners - What oil do you use?
Postby Jexintag » Thu Oct 26, 2006 4:55 pm
Time to do an oil change and i cant decide which oil to go with. I have decided that i want natural/mineral. Yes i have searched here and on Rotahavik - cant seem to find anything.
Bex :D
Jexintag
Postby mr pad » Thu Oct 26, 2006 5:38 pm
What made you decide you want mineral? Just curious...
How old is your motor, specs etc.
mr pad
Postby RS13 » Thu Oct 26, 2006 6:19 pm
Don't use synthetic! ALWAYS use mineral, rotaries premix the oil in with the fuel, and use it to internally lubricate the engine, so you need to have the right oil. I would recommend ringing around rotary builders, (not hard, just pick up a phone book or ask around) and ask what brand/W-rating they'd use.
RS13
Postby Dell'Orto » Thu Oct 26, 2006 6:56 pm
Nah, synthetic doesnt burn cleanly, it tends to leave ashy deposits. I just used Protec in all of mine.
Postby Jexintag » Thu Oct 26, 2006 8:01 pm
12a monster bridgeport.
one guy said go to repco and get castrol 15w40. My bf rekons to go to mazda and see what they recommend, but dont like the mazda people here and i was told by someone else to never use mazda oil in a rotary???
Someone else said that Motul was a good brand??
Yeah i think ringin round the engine builders and see what they reckon. It's just such a hard decision, everyone has a different opinion.
Decided on mineral because seems to be majority of what people recommend. Plus natural stuff always seems better than plastic to me anyway.
Jexintag
Postby Jexintag » Thu Oct 26, 2006 8:04 pm
and age of my engine.... not 100% sure. Had a rebuild about 4000ks ago, bout a year.
Jexintag
Postby hsmidy » Thu Oct 26, 2006 8:08 pm
depends what was in it origanily if its been using mineral oil and you go synthetic they tend to start weeping around the sump gasket(mineral oil cases some seals to expand) so when ya go to syntheic they shrink back down a bit and cause leaks, i use to run castrol gtx in my rx7s4 gtr never had any trubbles,
is it ported, if it is i recommend ya use some 2 stroke in ya fuel, saves ya seals and keeps them alive longer
hsmidy
Postby Jexintag » Thu Oct 26, 2006 8:13 pm
yip ported, i use moreys upper cylinder lube in my fuel.
Not sure whats in it now... possibly the castrol one from repco, as thats what the guy i bought it from recommended.
but i dont want to use the cheapest, would rather spend the extra and have my engine last longer.
Jexintag
Postby hsmidy » Thu Oct 26, 2006 8:18 pm
there is an special rotary oil and yeah wouldnt ya know it almost only in japan, ill try and find out the name of it again i think one place in the north island sells it but its expensive shit, supose to be the only oil that burns completly in a rotary.....dont know if ya want to go to those extremes but yeah, make sure ya get the right api for your engine, especally if its an older one, can cause havik other wise(exsesive oil leaking past ya oil control rings, fouling ruff running etc
hsmidy
Postby Jexintag » Thu Oct 26, 2006 8:35 pm
cool if you found out the name that would be good... prob dont wanna go to those extremes, depends on the price i guess. Still would be good to know anyway.
thanks everyone :D
anyone else got anything??
Jexintag
Postby AE82 FXGT » Thu Oct 26, 2006 8:51 pm
You might want to look into Castrol R30 too. I can remember someone told me it was good for rotories...
AE82 FXGT
Postby Jexintag » Fri Oct 27, 2006 8:41 am
I really like the sound of these three.
http://www.supercheapauto.co.nz/www/index.cfm?itemid=159
Jexintag
Postby Jexintag » Fri Oct 27, 2006 8:45 am
The Castrol R30 sounds good too, more for racing though.
http://www.castrol.com/castrol/productdetailmin.do?categoryId=8290037&contentId=6007689
Is it ok to use different oils at different times, as long as you do an oil change each time you use a different one???
Jexintag
Postby Jexintag » Fri Oct 27, 2006 8:48 am
Jexintag
Postby blackie » Fri Oct 27, 2006 1:08 pm
Jexintag wrote:Is it ok to use different oils at different times, as long as you do an oil change each time you use a different one???
yeah, just dont mix them up.. ie. dont 'top up' using a diff viscosity..
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1892
When my bros call.. dey get hit wit da chinnggggaayyy
blackie
Postby strx7 » Fri Oct 27, 2006 1:47 pm
Mobil 1 5W/50 - ditch the factory OMP. and premix the fuel with good 2 stroke oil.
Postby Jexintag » Fri Oct 27, 2006 2:18 pm
strx7 wrote:Mobil 1 5W/50 - ditch the factory OMP. and premix the fuel with good 2 stroke oil.
Thanks, Have done, but am using Moreys upper cylinder lube. I know it says on the bottle "warning this is not a replacement for 2stroke oil" but seems a few others on Rotahavik use it also and have had no problems with it. Also the main rotary engine builders recommend it.
have you heard anything about it?
Jexintag
Postby strx7 » Sat Oct 28, 2006 7:05 pm
i've seen alot alot of people premix with it, and or a 50-50 blend of it with 2 stroke oil
