Anyboby know how to replace the big heavy VVT pulley for a adjustable cam pulley or just a standard type pulley????
Slivertop, running turbo and NO vvt.
Give HiTech Motorsport in Pukekohe a call/email, they've done this before a few times. You'll have to make up a gear to suit the standard cam as I don't know of any off the shelf gear that'll bolt on & line up properly. You'll also need to block off the oil feed to the VVT setup, or you can redirect this into the head/cam bearings with a lil work.
