cracked radiator
cracked radiator
Postby JamesM » Fri Oct 27, 2006 8:56 am
my radiator is one with plastic top tank and its got a little crack in it so when engine is hot it bubbles and steams out of it.. is there any easy way to fix it? im not about to take it to get recond as i can just go to pap and get another. im just after a cheap and easy solution and if there is none il buy another.
James
Team Megasquirt
1984 AE86
180kW, 600Nm@wheels @ 16.5psi
JamesM
Postby Leon » Fri Oct 27, 2006 10:05 am
Get a price to have a new top tank put on by a radiator shop. It shouldn't be too scary.
Plastic top tanks crap out constantly, so the risk of a second hand one, is that it will do the same thing in a weeks time :( as it such a common failure item.
Postby JamesM » Fri Oct 27, 2006 12:33 pm
true. will go investigate.
also ive been lazy/not in nz and i need to put my homolgation forms in for cage. whats the email address to send the photos in?
Team Megasquirt
1984 AE86
JamesM
Postby Leon » Fri Oct 27, 2006 1:03 pm
it's on the top right corner of the homologation application :)
