Bazda wrote:Putting the 2mm head gasket will effect your squish area ratio. therefore reducing the power everywhere on the power curve. bring the squish ratio back up by using the gze low comp pistons and then u will bebale to use a much thinner head gasket.
no_8wire wrote:Bazda wrote:Putting the 2mm head gasket will effect your squish area ratio. therefore reducing the power everywhere on the power curve. bring the squish ratio back up by using the gze low comp pistons and then u will bebale to use a much thinner head gasket.
If I get a metal one made...surely 3mm of metal isnt going to squish like a composite one?
no_8wire wrote:ok...
maybe I will just get the conrods shorter than...and wait the 8 weeks...![]()
Just a question in theory though...If I was to run a 3mm composite type gasket...would it blow?
no_8wire wrote:hes running like 7.6:1 c/r though...
no_8wire wrote:??? I didnt understand a word you said sorry...
Bazda wrote:And i wasnt intending to run 27psi we just kept turning the boost up and it wasnt knocking, that was with a total advance of 16deg on boost.
True-No-Turbo wrote:no_8wire wrote:??? I didnt understand a word you said sorry...
no worrys I was just giving you an example of what quench is and how it affects combustion, what bit didnt you understand? allgood....
