Stealer Of Souls wrote:I've been told that if the TPS isn't set correct it can cause hunting idle.
Another way to check if the cold idle valve is shagged. Take off the intake and when the idle is hunting you can stick you finger over the big round hole at the bottom of the throttle body just in front of the butterfly. If the hunting stops then it's quite likely that valve is shagged.
I've killed several cold idle valves. They don't like the coolant getting hot... I found that anything above three quarters on my guage starts to kill them.
Stealer Of Souls wrote: I would first point the finger at the cold idle control valve.
Sensitive, but not that sensitive. If you marked it and put it back much the same it should be okay. Unless it was borderline to begin with.
repowered wrote:is this the cold idle control valve?
Stealer Of Souls wrote:The cold idle valve is supposed to shut completely when hot.
There is a spring that tries to pull that valve open and some wax that pushes it closed. But if the wax inside of the valve has died then it doesn't shut the valve properly. The engine's vaccum pulls the valve closing it (idle drops) then the vaccum drops and the spring pulls the valve open again (idle rises again). And this pretty much continues on that sort of path...
(I'm pretty sure I've got that around the right way, it always confuses me when I think about it too long)
repowered wrote:i sopose you wont be able to see it fully open as when you take it off it may have closed again as you will have to drain some coolant i guess.
