Long term storage...What do I need to do?
Postby no_8wire » Mon Oct 30, 2006 7:23 pm
Well the MR2 will be parked up for about a year in April....what do I need to do to make sure it will turn over/run when I get back and want to run it?
Fill the bores with oil?
no_8wire
Postby CaM » Mon Oct 30, 2006 7:43 pm
leave it in gear with the handbrake off
remove the battery incase it deicdes to start pissing acid everywhere. it'll be $&#$% by the time you get back anywho.
Id be inclined to remove the plugs, squirt a wee bit of oil (not much) down the bores and wind it over a few times with the plugs out, alhtough i doubt any corrosion's going to find it's way in anywho.
when you get back - new oils, coolant, filter, battery of course.
if you leave the handbrake off, the brakes wont be jammed on.....
wind it over with the coil lead/spark disabled til you get oil pressure
run it til hot
change the fluids
all good.
anythign else will rear it's head that nees doing fairly quickly, but it'll only be with brakes etc due to moisture in the fluid or sticking on or whatever...
don't forget to put the rego on hold or paid up until you get back, so as not to let the plates go dead
chur
CaM
Postby no_8wire » Mon Oct 30, 2006 7:47 pm
sweet.
If I get somebody to run it every two weeks for 1/2hr or till warm will I need to do any thing or will it be sweet?
no_8wire
Postby CaM » Mon Oct 30, 2006 7:54 pm
if you're gonna do that, then nah.
if they're going to roll round the block in it then even better i guess
CaM
Postby no_8wire » Mon Oct 30, 2006 8:11 pm
Sweet...guess there is some advantage to having younger brothers then... :lol:
no_8wire
Postby Mr Revhead » Mon Oct 30, 2006 8:51 pm
get one of those hippo anti moisture thngs and put inside and get some one to change it every few weeks
Postby flat_0ut » Mon Oct 30, 2006 8:58 pm
Maybe this should get stickied? I'm sure this has been covered before a few times.
"To most the sky is the limit, to a lucky few, the sky is home."
flat_0ut
Postby no_8wire » Mon Oct 30, 2006 9:53 pm
Mr Revhead wrote:get one of those hippo anti moisture thngs and put inside and get some one to change it every few weeks
Got one in there at the moment...surprising how much water it sucks up...
no_8wire
