cr1mnl wrote:not all ae101s are superslut but yeah trying to find one for 2.5k is another story. some people say the ae101 runs a smaller pulley on the s/c but i havent compared the two myself. most standard ze's seem to run around 7psi however changing the crank pulley to a 175mm dia should see you get 12-14psi depending on s/c condition. One other thing all the map sensor verions I've driven all seem to have a dip in power at 5500rpm. Not sure if its the same with afm. Other people have noticed this too and theres varying opinions on what causes it, some say ecu, some say supercharger efficency.
IH8TEC wrote:on my car, ae92 with afm, i had 14psi pulley (but ran 12 and 13.5on cold night) also had pod and exhaust, thats all and i had 101.4kw atw on the dyno. and also ran consistant 14.7's. and that used to beat ae101 gtz's with those mods plus some.
so maybe that will answer your question
~SlideWays~ wrote:ae101's are heavier too from what I understand.
Dirtbag wrote:Just out of interest, why would it run less on a cold night?
