st185 overboosting? Help me Please!
Postby 185Addict » Sun Nov 05, 2006 4:30 pm
Ive got an st185 gt4 i was running a Racepro boost tap and could not get it to cut would just run an open wastegate. I upgraded to a gizzmo IBC hoping this would fix it, But still the same i have replaced the actuator with another and i am still having the same problem. Is the wastegate on the gt4 to small to run these this is the only explanation in the IBC manual. ps. runs perfect on 7 pound with controller dissabled.
St185 GT-Four
185Addict
Postby Al » Sun Nov 05, 2006 8:49 pm
Have you disabled the t/vsv? My old mr2 used to freeboost with it still enabled and a bleed valve. Disable it and you will be sorted.
Al
Postby 185Addict » Sun Nov 05, 2006 9:28 pm
Cheers pal ill try it tomorrow nite :D
St185 GT-Four
185Addict
Postby Boosted_162 » Sun Nov 05, 2006 10:10 pm
Al wrote:Have you disabled the t/vsv? My old mr2 used to freeboost with it still enabled and a bleed valve. Disable it and you will be sorted.
Thats why my boost is all up the wack :lol: :lol: :lol:
Postby Adydas » Mon Nov 06, 2006 8:34 am
So fix it auu!!!
Adydas
Postby Redd » Sun Nov 12, 2006 2:12 pm
Can someone help me out what is t/vsv?
Current Car : 2004 1kz Hilux
Previous Cars : 1978 Ford Escort on 15" reflexes, 1978 Vauxall Chevette powered by a 3K, 1991 ST182 Toyota Celica, 2x SW20 Turbos, 1985 R31 RB20det and an S14 ks
Redd
Postby Al » Sun Nov 12, 2006 2:59 pm
Al
