I've got a silvertop turbo and since i have rebuilt the engine with ZE pistons, I have never hooked up the VVT as i am running a LINK.
MAIN PROBLEM......
The VVT pulley Sounds like a REALLY loud tappet, and im woundering if it is because it has never operated and let oil though to it.
The other problem is... If a activate it if that will cause the cam to advance and contact the pistons(being 16v pistons).
Is anybody running a similar set up and using VVT??
And, Doe's it make any difference on a turbo set if you use VVT??
