20v 4age cams spec
20v 4age cams spec
Postby NA Drifter » Wed Nov 08, 2006 5:31 pm
So far, only manage to find blue top and red top 16v cams spec.
For silvertop 20v, they are 7.97 (in) /7.60 (ex)
For Blacktop 20v, they are 8.20 (in) /7.60 (ex)
The problem is, I can't find the duration for them. Anyone know what the duration for the 20v 4age cams?
Also, what 20v motor runs/drive like if the VVT not working?
Thanks
Keith
Keith
NA Drifter
Re: 20v 4age cams spec
Postby Santa'sBoostinSleigh » Wed Nov 08, 2006 5:41 pm
NA Drifter wrote:Also, what 20v motor runs/drive like if the VVT not working?
edit*im dyslexic*
just disconnect your VVT wire on your ECU and see for yourself
Last edited by Santa'sBoostinSleigh on Wed Nov 08, 2006 11:11 pm, edited 1 time in total.
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby NA Drifter » Wed Nov 08, 2006 5:58 pm
problem is, I don't own a 20v motor.... :?
I though VVT is off under 1700rpm @ less than 15% trottle angle , then on, then off again after 6400rpm.
So, idle should be no problem?
Also I can't find any wiring diagram for ae111 / 20v 4AGE blacktop.
I'm wondering why there is only 3 wires for the TPS in the blacktop 4AGE acording to the ECU pin out.. and don't know what the "EVP" in the 16 pin socket for...??
ANyone?
Keith
NA Drifter
Postby Santa'sBoostinSleigh » Wed Nov 08, 2006 6:15 pm
ive got one, flick me an email and i'll send it to ya
Santa's Mega Sale
Postby Bazda » Wed Nov 08, 2006 6:40 pm
the vvt is off under xx rpm and only comes on at certain rpm and tps position.
if u stick the vvt on all the time it will idle rough as.
Postby 85AW20v » Wed Nov 08, 2006 8:59 pm
If it's not working at all, it'll idle fine. When I hooked mine up after the transplant into the AW, I picked up about a second a lap at Taupo on the old track.
See ya
Simon
85 MR2 20v
85AW20v
Postby Santa'sBoostinSleigh » Wed Nov 08, 2006 11:10 pm
sorry i got dyslexic on my initial post, VVT on at idle makes it sound like a tractor, noramally its off at idle
Santa's Mega Sale
Postby NA Drifter » Thu Nov 09, 2006 12:34 am
cool, thanks alot.
Anyone have any info about the 20v cams duration?
Keith
NA Drifter
Postby Bazda » Thu Nov 09, 2006 10:31 am
on this website at the bottom
http://www.billzilla.org/4agstock.htm
Postby AceSniper » Thu Nov 09, 2006 4:31 pm
most people say 250deg
AceSniper
Postby NA Drifter » Thu Nov 09, 2006 11:30 pm
yup is 250. And I got alot more info for what i need.
Everything seems to be sorted now.
Thank you.
Keith
NA Drifter
