4age head bolts
4age head bolts
Postby drftnmaz » Wed Nov 08, 2006 5:22 pm
i need some new head bolts for my turbo 5k.. and talking to some1 they said i should use 4age ones, they also thought that the 16v ones used two different types of bolt short on one side and long on the other, is this true?
what is the torque for the factory bolts? i can only find the tighten to 30ft then turn 90 and then another 90?
someone else i was talking to reconed the 20V heads use all the same bolts and they are the ones im after, can aomeone confirm?
and if you do have some old bolts lying around and could measure them and stick up the specs that would be mint. (maybe even a pic?)
drftnmaz
Postby Mr Revhead » Wed Nov 08, 2006 5:25 pm
yes 16v are shorter on one side
20v ones the same length
Postby drftnmaz » Wed Nov 08, 2006 10:15 pm
cool, so whos got a old bolt lying round they could quickly measure?
does anyone stock the arp bolts for a 20V? i checked with segidins and they only had 16V listings :?
drftnmaz
Postby Mr Revhead » Thu Nov 09, 2006 9:04 am
cant get ARP head bolts for the 20v
Postby AceSniper » Thu Nov 09, 2006 4:59 pm
you can... sorta... buy two sets of the 16v kits and only use the long ones :lol:
AceSniper
Postby Mr Revhead » Thu Nov 09, 2006 5:04 pm
have you tried it?
i sent a 20v head bolt to ARP and they couldnt match any up...
Postby AceSniper » Thu Nov 09, 2006 7:45 pm
nar I dont know for a fact so yea ignore that comment unless your sure,
what about stock ones check out how long 16v one is against the 20v one...
AceSniper
Postby drftnmaz » Thu Nov 09, 2006 11:16 pm
i measured my stock one today it had a 10x1.25 thread and was just under 4 1/2" long. can use a 5" if its a stud rather than a bolt. anyone know where to get something along those lines?
2 16V arp sets is gonna be pricey as.... i will get proper arp studs but the next shipment isnt for a while so i need something to use for trackday next week 8O
drftnmaz
Postby AceSniper » Thu Nov 09, 2006 11:44 pm
bolt it down, tig the bolts to the head, then do a tidy weld around the head/block ;)
AceSniper
