slighty_sykotic wrote:Awesome news about the LC1 then.
But what kind of connections does it have on the end of the cable?
RomanV wrote:Why oh why would they design this fancy new ECU, with all of these features, and then give it only 2 injector outputs?
It doesnt make sense to me, even on a 4 cyl engine, not to mention a 6 or 8.
I know that it probably doesnt matter a huge amount at WOT and high RPM where the injector duty cycles are high anyway, but... it just seems wrong.
Firing two injectors at the same time is just plain.... rangy, I doubt the factory ECU on my car does that, and I dont plan on taking a step backwards from what I've already got.
*sigh*
I think I understand why some people are so insistant on motec etc.
HRT wrote:As above, the LEM is supposed to be the basic entry-level kind of aftermarket ECU. What does a basic Motec retail for? I'd guess the price would be more on par with a G2 (standing here waiting to be corrected).
vvega wrote:id take the motec even if it was sligthly more expensive
slighty_sykotic wrote:And being that the g3 and g2 are the same platform, I believe you might be able to transfer maps from one to the other? So you start with the base g3 and once you need the extra inputs and outputs of the g2, and a higher boost you can buy the g2 and transfer maps.
And I believe the resolution is now up nearer the motec etc now, as well as the "boxes" are adjustable.
And a side note, its confusing that the higher spec model as the lower number (g2).
slighty_sykotic wrote:Are you sure?
vvega wrote:and thats just there base model
it just gets better from there
they also offer telemetry and the OMFG how trick is that MOTEC dash
i guess the new links are a bit better than there predesesors
but IMO they priced themselves out of teh game tring to compete with motec and aurtronic
just out of curosity have you ever seen the motch sofware and link sofware side by side ??
thats enough by itself to pay teh extra biccys
wayne
