replacing ae92 handbrake cable
Postby deaf_rattle » Sat Nov 11, 2006 6:41 pm
Has anyone done this? I had a quick nosey under the car, and i could see where the two cables from the rear wheels go, but couldnt see where the cable is sposed to come from the cabin.
Is it between the heat shields and the bottom of the car?
what to do?
Postby CAMB01 » Sat Nov 11, 2006 6:43 pm
Remove the heat shields under the car and you should see where the cable comes out. To make it easier you could drop the exhaust first.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby bluemaumau » Sun Nov 12, 2006 12:19 am
above heatsheild, sweet
