Diesel oil in a petrol engine
Postby BZ Touring » Tue Nov 14, 2006 8:52 am
Lads. The wagon's in for a service (96 BZ Touring), and I have been advised to use Castrol RX Super Diesel :? to give the engine and seals a bit of a recondition in an attempt to reduce oil consumption. This will be just a one off, next service normal oil (15W40) will go back in. Any thoughts (constructive ones based on experience, not obvious ones based around "diesel oil probably shouldn't go in a petrol engine"). Cheers.
BZ Touring
Postby Chickenman » Tue Nov 14, 2006 8:58 am
Pretty much all oil has seal recondiitioning additives etc, I can't see why diesel oil would have too much more.
Can't recommend any specific oil but if it's going through a bit of oil (which is normal for a blacktop.. especially if you drive it cold) and there is none on the ground it's obviously not your seals.
Use the best oil you can afford and be prepared to top it up every so often it's just the way it is for blacktops (they're getting up over 100 000 km's now).
I'm not entirely sure the problem would disappear after a complete rebuild anyway.
Baby Jesus
Chickenman
I Am The Walrus!
Postby BZ Touring » Tue Nov 14, 2006 9:09 am
Yeah, to be fair it's not using a hell of a lot of oil (at least no more than would be expected based on feedback from this forum).
Apparently the diesel oil is better at cleaning engine deposits. So as long as there are no negatives, I can't see why not. It might turn out to be the magic atedote to all the interesting issues that crop up with 20 valves :roll:
BZ Touring
Postby evil_si » Tue Nov 14, 2006 9:17 am
i run my cars on a diesel oil, mobil delvac 15w40 permanently,
surprisingly considering the detergent and carbon retaining properties diesel oil has, i find it stays clean for longer periods,
ie still goldy after 5000km, and the car has done 260000k
evil_si
Postby Jebus » Tue Nov 14, 2006 9:19 am
Diesels oils do have detergents in them to clean up the by-products of diesel combustion, by-products that petrol engine dont make and the detergents can be harmful to a petrol engine, even losing compression.
Diesels run much higher compression therefore much more heat and the oil is made to suit this.
You can run it for a couple of hundred kays to flush the engine (not something I would do on a blacktop), but running it for long periods of time will do no good, most probaly bad. Id just give it a 15 minute flush with kerosene then carry on running good oils. "High mileage Oils" have seal protectant additives so give them a whirl if youre really concerned.
Jebus
Postby BZ Touring » Tue Nov 14, 2006 9:42 am
Interesting. Why would you not do an engine flush with a black top?
BZ Touring
Postby BZ Touring » Tue Nov 14, 2006 9:46 am
Also, what compression do diesel engines typically operate at? The reason I ask is that I understood that 20 valves also run at quite a high compression (relative to other petrol engines that is).
BZ Touring
Postby Jebus » Tue Nov 14, 2006 9:47 am
Its still a relatively new motor, as you said before yours doesnt have a problem, its fine. Wether or not you flush it isnt going to make a difference, you arent going to goin horsepower, you wont notice a thing.
Only possibility is that you might damage your motor, better of leaving it how it is and running nice oil.
Jebus
Postby Jebus » Tue Nov 14, 2006 9:51 am
BZ Touring wrote:Also, what compression do diesel engines typically operate at? The reason I ask is that I understood that 20 valves also run at quite a high compression (relative to other petrol engines that is).
Between 15 to 20:1 typically at the higher end of the scale, against a blacktops 11:1. Diesel engine takes in air, compresses it massively and the fuel combusts from the heat of the compressed air, no spark like on a petrol engine.
Jebus
Postby BZ Touring » Tue Nov 14, 2006 9:51 am
Yeah, nah, yeah. Increasing horsepower isn't my motivation. Just trying to keep the engine in good nick.
BZ Touring
Postby Jebus » Tue Nov 14, 2006 9:58 am
BZ Touring wrote:Yeah, nah, yeah.
Yeah or Nah?? :lol:
BZ Touring wrote:Increasing horsepower isn't my motivation. Just trying to keep the engine in good nick.
Just look after it run good oil and a good filter.
Jebus
Postby strx7 » Tue Nov 14, 2006 7:48 pm
i have personally seen 2 engines come into work which accidently got deisel oil in them. both siezed big ends and or mains as a result, but man they were clean inside......
Postby sergei » Tue Nov 14, 2006 8:19 pm
I don't see diesel oil siezing bearings. In fact diesel oil theoretically should be better for bearings aswell, because of stress involved on the bearings is much higher than on petrol, due to compression and near detonation self ignition. Also diesel pistons are very heavy. Have you noticed how diesel engine clanks on idle?
Diesel oil has got lots of detergent additives, because of that it could be bad for seals. Anyway for some reason diesel use different compound for seals.
Postby Mr Revhead » Tue Nov 14, 2006 9:57 pm
i wouldnt run an engine for 15mins on kerosine 8O
Postby evil_si » Tue Nov 14, 2006 11:09 pm
Mr Revhead wrote:i wouldnt run an engine for 15mins on kerosine 8O
i would if i wanted to do a destruction test :D
evil_si
Postby sergei » Wed Nov 15, 2006 12:09 am
on idle nothing will happen - for really long a while (untill kerosene reaches flash poin that is) :) probably would be spectacular at the end...
Postby Jebus » Wed Nov 15, 2006 8:28 am
Heh, yes only on idle, and with the old oil in it still. :lol:
Works a treat, fixed all the blackening of oil problems in the smallport.
Jebus
Postby Mr Revhead » Wed Nov 15, 2006 8:59 am
hehe thats a better option
i have previosuly used ATF for that.
in a townace where i too out the bung and nothing came out.....
Postby Ae92typeX » Wed Nov 15, 2006 2:03 pm
Ive run diesel oil in some cars for big k's without issue. Both compression and spark based oils have their rating on every oil pack. Some new diesel oils are at an 's' rating which is equal to what most cars here require.
If it was damaging to a spark engine, why would it have a rating?
anyway, from experience, Ive had no issues at all, but everyone is entitled to their opinion
Ae92typeX
Postby Mr Revhead » Wed Nov 15, 2006 2:16 pm
interesting tren iv noticed is ppl buying magnatec for thier surfs
