Had an understanding and have now become confused. Only factual answers from people who know what theyre talking about please
Yea but electric pumps are more efficent, and don't speed up with higher revs meaning less power used.pyro_sniper2002 wrote:Then you loose power with more load on the alternator. The load does not just magically go away.
??????????????sergei wrote:Why do you think that lights power feed is somehow separate from battery?
Battery is directly wired to alternator (no relays or other active or passive elements apart from 100+ Amp fuse). You will find that the light problem might be in bad grounding and coroded contacts and wires.... If you ever pulled toyota looms apart you will find there is really fat white wire which goes directly from battery to alternator (splitting along the way to inside and fuse box)..
