by wde_bdy » Tue Nov 14, 2006 5:32 pm
The bolt on option is generally a no go for FWD's/4WD's unless you want massive track increases and flares etc. As they already run around a P40 type offset you will end up needing P55 or more wheels to get back to standard track. Assuming the wheels you want are a more RWD type offset you effectively double the problem. Some certifiers aren't happy with you pushing the wheels out too far on FWD style hubs and it can do nasty stuff to steering geometry.
Hubs off a Supra are probably a no go but look at SW20 MR2 and I believe some later model Camry's ran 5x114 as well, can someone confirm that? You will probably find the Camry front and SW20 rears are the closest solution. Try cross referencing the bearings as a starting point.
Callum
