Air Conditioning (no im not ripping it out)
Postby Alex B » Tue Nov 14, 2006 11:48 pm
Car = SW20 MR2
When i bought the car it was not working, had it re gassed a while ago as a perk.
Still full of gas by the sounds, and the clutch gets 12V when i turn the ac on. Wounder if the magnetic clutch is stuffed. Can you replace these without loosing the gas?
Postby sergei » Wed Nov 15, 2006 12:14 am
yep.
Remove belt.
Undo central bolt on the clutch pulley, pull that out, there will be a circlip, remove that, disconnect the power from clutch electric magnet (plug) unbolt ground from it, you can pull that out and replace in reverse order.
This is all from memory ;)... clutch electric magnets are interchangable on most toyotas just have to redo the power plug if different...
Postby Alex B » Wed Nov 15, 2006 12:42 am
Cheers sergi. Looks like a fun job on the MR :lol:
Postby Akane » Wed Nov 15, 2006 4:55 am
It's actually not that bad on the MR2 coz it's accessable via the front of the rear/right wheel.
And if yours is a pre-96, that recharge sure is a perk coz last time I wanna get it charged, it's $400+ and that's 4 years ago.
Postby Alex B » Wed Nov 15, 2006 5:20 pm
Yea he still had R12a, i didnt even think they kept it anymore :?
