C52 ratios, AT160/AW11/AE82/ae92/AE91
Postby crispy'86 » Mon Nov 20, 2006 10:27 pm
Okay i've searched but just found one post about ratios for c52 boxes, trouble is i think there are a few different ratios for the different model cars. I've driven g/f's car with c52 in her ae91 and c52 and the ratios are nicely spread, however in my fxgt i'm using the c52 from an at160 corona coupe which has a big drop in revs going from 2nd to 3rd. Who has all the ratios for all the above models i just listed.
Thanks in advance
crispy'86
Postby AceSniper » Tue Nov 21, 2006 1:47 pm
I might not be right here...
c52 is the type of box & gear set, the only thing that may differ in that is the diff ratio? (maybe import vs nz new gears differ?)
sure her car dosnt have a c56? they have a closer 3rd and 4th gear
AceSniper
Postby crispy'86 » Tue Nov 21, 2006 10:05 pm
AceSniper wrote:I might not be right here...
hmmm it's 5afe and have to read the firewall plate to double check , but anyone got any info on ratios,
crispy'86
Postby fangsport » Tue Nov 21, 2006 10:10 pm
i thought it had a C-50, which is the same as the 4AFE ae101 i was servicing today
fangsport
Postby crispy'86 » Tue Nov 21, 2006 10:13 pm
As i said i'll have to double check, i looked in a hurry when i was doing some other work on it
crispy'86
Postby crispy'86 » Thu Nov 23, 2006 6:17 pm
going to do some research find a workshop manual for both and see if i can get the ratios for the at160 corona (celica) and aw11 boxes
crispy'86
Postby crispy'86 » Sun Dec 17, 2006 7:48 pm
All the c52 boxes in at160/ ae82/ ae92 4age powered all have same gear ratios and diff ratio
crispy'86
