rwd smallport 4age auto ecu
Postby panda_dan » Fri Dec 01, 2006 9:38 am
I am dropping a smallport 4age into my ae85.
It was auto and i am wondering what i will have to do to the ecu in order to run it.
Anyone had any experience here?
Thanks - Danny
panda_dan
smallport
Postby panda_dan » Fri Dec 01, 2006 3:26 pm
Sorry my post wasnt so clear
The gearbox on the engine was auto and i am wondering what i will have to do to the ecu in order to run it with w55.
panda_dan
Postby Rick » Fri Dec 01, 2006 3:34 pm
You dont have to do anything to the ecu, you only need to bridge the gear selector switch.
switch
Postby panda_dan » Fri Dec 01, 2006 3:36 pm
Is that so it can idle ?
panda_dan
Postby JamesM » Fri Dec 01, 2006 3:37 pm
what will happen if you dont?
Team Megasquirt
1984 AE86
180kW, 600Nm@wheels @ 16.5psi
JamesM
Postby HELBND » Fri Dec 01, 2006 3:39 pm
JamesM wrote:what will happen if you dont?
it wont start - auto has to think youre in park or nuetral before itll let you start it
HELBND
bridge
Postby panda_dan » Fri Dec 01, 2006 3:44 pm
How do you bridge the gear selector switch?
Once the selector switch is bridged am i likely to encounter any probs in the future?
Thanks guys
panda_dan
Postby JamesM » Fri Dec 01, 2006 3:48 pm
ah yes i thought it was something like that.. couldnt remember.. did it on friends 180sx when he changed to manual
Team Megasquirt
1984 AE86
JamesM
switch
Postby panda_dan » Fri Dec 01, 2006 3:55 pm
How do you bridge the gear selector switch? Rick do you know?
Thanks guys
panda_dan
Re: switch
Postby Rick » Fri Dec 01, 2006 5:25 pm
panda_dan wrote:How do you bridge the gear selector switch? Rick do you know?
The switch is located at the front of the car on the gear box, just follow the gear selector cable to it, you will see a plug with about 6 or so wires going to it, I think its the black wire and a black with white stripe (please double check) you will need to bridge/join those two wires together.
panda_dan wrote:Once the selector switch is bridged am i likely to encounter any probs in the future?
I hope not :P,
