I've never attempted this before so this is a question for those who have. What sort of sanding paper would I need to use to get the old coat removed from the rim so it's ready to be re-coated?
Also where do I purchase this mighty sanding paper from.
Otherwise if anyone knows of a drill bit I can slap on the end of the drill to clean the rims that would probably go allot faster than by hand.
Thanking you muchly,
