Adamal wrote:This is XRyanX. His car is so low that he has to drive over speed bumps diagonally. HARDEN THE $$% UP XRYANX!!
pc wrote:There is a law, can't remember specifics, but I think you need a cert if the lowest point of your car is below 100mm.
xRyanx wrote:In regards to my AE111 levin, im thinking about lowering it some more, purely for asthetics. As its on adjustable suspension its not biggie to drop it some more, and is free.
JT wrote:Check the measurement on the cert tag, assuming you have one
JT wrote:Also, once your lower arms start angling above horizontal you'll get all sorts of problems with alignment. Camber, bumpsteer, tracking are all affected.
I think 100mm ground clearance is a practical minimum.
Santa'sBoostinSleigh wrote:if you already have a cert for the adjusties, then you will need it re-certed at a different height. no ifs no buts.
l1ttle_d3vil wrote:Santa'sBoostinSleigh wrote:if you already have a cert for the adjusties, then you will need it re-certed at a different height. no ifs no buts.
is this the case even if the car is still above 100mm though??
l1ttle_d3vil wrote:and excuse my ignorance, but what would the point be in having adjustables if you need to get it recerted whenever you change the height? isnt that the idea of having adjustable suspension? or are they more aimed at track/race cars instead of road cars? or am i just missing something all together??
l1ttle_d3vil wrote:or are they more aimed at track/race cars iSanta'sBoostinSleigh wrote:if you already have a cert for the adjusties, then you will need it re-certed at a different height. no ifs no buts.
l1ttle_d3vil wrote: and excuse my ignorance, but what would the point be in having adjustables if you need to get it recerted whenever you change the height? isnt that the idea of having adjustable suspension? or are they more aimed at track/race cars instead of road cars? or am i just missing something all together??
soopachargen wrote:One of the factors thats got me heading towards D2 coilovers is that they have their ride height adjustment by moving the lower mount of the shock up or down the shaft on a thread rather than moving the spring perch and altering your spring pre-load, so you avoid changing the travel of the spring.
some of the new-beaut adjustables have a fully threaded body and also have the lower mounting bushing incorperated into a threaded section, thus allowing a ride height change without a spring rate change.JT wrote:soopachargen wrote:One of the factors thats got me heading towards D2 coilovers is that they have their ride height adjustment by moving the lower mount of the shock up or down the shaft on a thread rather than moving the spring perch and altering your spring pre-load, so you avoid changing the travel of the spring.
Please explain![]()
You can't change the height of a car without moving the spring perch or changing the spring.
