torsen diff
torsen diff
Postby audi man » Mon Dec 04, 2006 1:37 pm
well last friday night i busted 2 torsen diffs on the line, now looking for another torsen.
1.5 jz mk3 supra,675rwkws at 28psi and 723rwkws at 32psi
audi man
Postby Santa'sBoostinSleigh » Mon Dec 04, 2006 2:04 pm
the point is?
if you want to buy one, this should be in the for sale/wanted section
if you want advice, ask
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby gmacrae » Mon Dec 04, 2006 3:47 pm
John, sounds like you've got some major wheel hop goin? What tyres are you running? Have you replaced any suspension bushes in the rear or are they all stock?
gmacrae
Postby audi man » Mon Dec 04, 2006 3:55 pm
gmacrae wrote:John, sounds like you've got some major wheel hop goin? What tyres are you running? Have you replaced any suspension bushes in the rear or are they all stock?
M/T slicks and hardend suspension and new bushes, but i think 500kws was the limit of the torsen.
audi man
Postby audi man » Mon Dec 04, 2006 3:57 pm
Santa'sBoostinSleigh wrote:the point is?
POINT is seeing if there is some one out there that knows of a stronger diff not to buy another torsen to brake.
audi man
Postby AceSniper » Mon Dec 04, 2006 4:10 pm
Why not run a clutch type lsd... alot more $ than stock torsens but will hold what your throwing at it, and if not.. shim it up and throw more at it.
AceSniper
Postby Al » Mon Dec 04, 2006 5:06 pm
You have to have some slip in the driveline somewhere. If you dont, something will break. Wether it be tyres, clutch or diff. Preferably tyres!
You could look at going to an auto setup with stall converter, 4 link rear end, that way you will have consistant launches and it won't break. However it may become a tad boring.
Al
Postby Silent Knight » Mon Dec 04, 2006 6:40 pm
He's been using an auto untill the recent manual conversion.
Blew up 14/15 boxes so far... :P
Silent Knight
Postby Al » Mon Dec 04, 2006 8:18 pm
Toyota autos? Try a chevy c4 or something.
Al
Postby gmacrae » Mon Dec 04, 2006 9:01 pm
audi man wrote:M/T slicks and hardend suspension and new bushes, but i think 500kws was the limit of the torsen.
Are you actually getting much wheel hop? Have you done just the springs or the shocks also? Stiffer springs but stock(ish) shocks could make wheel hop worse, might need more rebound damping maybe?
I know the mkiv auto torsen can take plenty of power, pretty sure there are cars doing 8's and 9's on that diff, is the mk3 torsen actually much weaker?
Either way, sounds like it might be time for a TRD or Cusco diff head 8O
gmacrae
Postby Mr Revhead » Mon Dec 04, 2006 9:36 pm
al!! FORD c4. chevy do the powerglide or turbo 350/400s etc
Postby Al » Mon Dec 04, 2006 9:51 pm
A dinosaur by any other name? :lol:
Al
Postby the fallen303 » Mon Dec 04, 2006 10:53 pm
we've had that argument about the c4 for the past few years now since johns been building the car and breaking stuff, still hasn't worked :wink:
true house of JZ
Stay true to the origin
the fallen303
Postby Dell'Orto » Tue Dec 05, 2006 1:04 am
Perhaps go to Croydon's and have a yarn with Graeme? I dont think he solved his diff shattering issues when it was manual though.
Postby Si » Wed Dec 06, 2006 6:56 pm
what ratio diff are you using john?
would a mechanical 2way not handle the power better than the torsen?
Current: , '96 SubaruImpreza
Si
Postby audi man » Wed Dec 06, 2006 7:02 pm
3.9 and the second one was a 4.1.
audi man
Postby vvega » Wed Dec 06, 2006 7:09 pm
mini spool it and get over it :D
vvega
Postby 2jayzgte » Wed Dec 06, 2006 7:21 pm
audi man wrote:3.9 and the second one was a 4.1.
Are the torsen diffs you are using MKIV Torsen diffs????
The only other suggestion I would say is get a properly built tranny for the drag racing..
I no this is a long shot but theres a guy Sth Australia I think the place is called MV automatics apparently he builds the Factory A340Es to suit I got the info outta HPI a Aussie publication but this guy is meant to be the man.
2jayzgte
Postby audi man » Wed Dec 06, 2006 7:24 pm
We are thinking of putting nyles c4 tranny in with a shot of nos to get it of the line.
audi man
