HRT wrote:Or not spend $5000 on a bodykit and wheels and then try to spend half of that on the engine
Or spend heaps on the engine and try to muck around with a factory ECu
crnkin wrote:yeah not attacking or anything. But to make sweeping generalisations like not running a free flowing exhaust or, using forged pistons, or using a log manifold, are to say the least "sweeping generalisations", and fit the purpose and the time and place perfectly, and to infact say that doing anything but is half arsed, is a) hipocritical, and b) wrong.
(just opinion, not an attack!)
I mean, for a start, you researched and done everything "properly" (which is good!, saves you and me time), and probably took the high compression route as something someone in "the know" suggested to you, and you researched further, then proceeded?
Did you know there was a stock 4age smallport high comp running 15psi on a t3/4 with 210kw atw 3 years ago?
It was done half arsed, it was on trademe, and it was cheap. It also produced awesome power.
Not saying that "half arsed" as you put it, or "doing the trick" as 50% of the other population would, is better than doing it with lots of time, thought, planning and MONEY, but I am however acknowledging that it is one way of doing it.
I bet we could both throw 5g at a 4age, and come out with completely different characteristics, with you spending the money all around, and me spending it on what I deem to be important, and youd like it, and id like yours.
So, please reconsider "half assed bullshiit" more of like "Hutt stylez/crnkin stylez with power on a budget, with all work done by the owner, and learning along the way, having fun"
Cher
Big post, but just got back from town and the girlfriend still aint back
True-No-Turbo wrote:HRT wrote:Or not spend $5000 on a bodykit and wheels and then try to spend half of that on the engine
yeah I fully agree there, no point really going the turbo route if you are not putting ecu etc into your budget.
My sh*ta made 126 atw after doing conversion, a pitaful h/p gain from being supercharged really and it never will be worthwhile if your just going to limit its capabilitys with sh*t stock ecus.
I have since spent another 2.6k on a G3, pump bla bla, and still getting money together to get it in and happening. It would of been alot cheaper to buy a gtz already converted and tuned but wheres the fun in that?
I know my car needs a few things to make it a bit more nicer but its not a priority to me, getting the most out of my turbo is.
go before show definately
Infinite wrote:i have a 20v silver top levin with a MINES ecu in it would that be anyuse if turbo'd? its non programable or anyone know what they improvenarh im not thinking of making a 4agte lol mite drop my 3sgte into my levin tho cause its setup way better just needs a bit of bodywork :/
HRT wrote:Anyone know what CR you get out of an 8.9 bottom end with standard Silvertop head on btw?
antonio wrote:Ive heard from friends of people turboing 4afe's and silvertop 4ages, and didn't even muck around with the ecu's, but done some other mods but not sure of what had been done, and ran it around 4 to 8 pound boost and it ran sweet.
Has anyone know of people doing this. I was thinking about doing it to my 4afefor fun and run it low like 5 pound, see what happens, only cause im dropping a worked silvertop in it latter. What use think will it last or my mates
talking poohaa!
dash wrote:yep,
there are literally thousands of turbo conversions this side of the pond rippin it up using rising rate FPRs.
Vortec 12:1 FMU (fuel) and MSD BTM (timing retard) are the most popular components, ~$150-170 each new, half that if used. Both remain transparent until boost. Some of these street cars have 12 second ET & last years.
A piggyback is the next step up for finer tuning. A SAFC fuel tuner perhaps the single most popular device sold. The $300 Greddy emanage has proven itself in the competent DIYer hands also.
Spending lots of money is optional.
