ae101 4agze engine swap
Postby mart1975 » Sat Dec 02, 2006 5:13 am
ill be changing my 4agze for a later spec ae101 4agze in my mr2.
i dont suppose anyone has done this swap allready and has a wiring diagram?? many thanks
mart1975
Re: ae101 4agze engine swap
Postby Crucible » Sat Dec 02, 2006 4:53 pm
mart1975 wrote:ill be changing my 4agze for a later spec ae101 4agze in my mr2.
Wouldnt it be just a straight swap over? just interchanging between engines as need be?
Crucible
Real Life Mechanic
Postby mart1975 » Sat Dec 02, 2006 9:56 pm
the early one has an afm where as the later ones use map sensors. i think this will be the main difficulty.
mart1975
Postby Dell'Orto » Sat Dec 02, 2006 10:39 pm
If you're just replacing a blown motor with a good one, just swap the short blocks over. Saves having to fiddle with ECU's and what have you.
Postby mart1975 » Mon Dec 04, 2006 9:22 am
the engines fine, the 101 just has 165 bhp rather than 145.
mart1975
Postby crnkin » Mon Dec 04, 2006 11:29 am
yes, but the reason WHY it has 165 bhp (tui ad) is why you will have difficulty.
deaf_homo "currrently yes"
crnkin
Postby mart1975 » Mon Dec 04, 2006 10:38 pm
what is it that gives it the extra hp as i believe the block is the same? perhaps i can just swap certain parts?
mart1975
Postby Crucible » Mon Dec 04, 2006 10:45 pm
mart1975 wrote:what is it that gives it the extra hp as i believe the block is the same? perhaps i can just swap certain parts?
higher static compression ratio
smallport head
smaller s/c pulley
Crucible
Real Life Mechanic
Postby sergei » Mon Dec 04, 2006 11:02 pm
Different ECU. There is a rumour that AE92 MAP ECU is the best one (as in no power loss after ~5500rpm, in AE101).
Postby mart1975 » Tue Dec 05, 2006 9:56 am
so basically apart from the rumoured gain with the map sensor i should still see a 20 hp gain by using my ecu, afm etc on the later block?
mart1975
Postby BZG_UNIT » Tue Dec 05, 2006 5:58 pm
can i buy your other 4agze?
1997 Toyota Trueno
1990 Toyota Trueno GTZ
BZG_UNIT
Postby Pelo » Tue Dec 05, 2006 6:09 pm
My MR2 has an AE101 engine, using the aw11 distributor ecu and AFM, runs just fine. Essentially the same engine just different electronics. Easy swap, I don't know if it would be worth the effort unless your old motor was stuffed though.
Pelo
Postby MR2SIK » Tue Dec 05, 2006 7:47 pm
if your just after more power, why not just fit a larger pulley kit to your existing setup? the afm version pulls like a school boy to redline, no 5500 drop off.
2011 Ford Mondeo tdci.
1990 MR2 GT garage queen
MR2SIK
Postby Crucible » Tue Dec 05, 2006 9:44 pm
MR2SIK wrote:if your just after more power, why not just fit a larger pulley kit to your existing setup? the afm version pulls like a school boy to redline, no 5500 drop off.
yeap, and upgrading to a water/air cooler will make it better again.
Crucible
Real Life Mechanic
Postby mart1975 » Tue Dec 12, 2006 8:02 am
bzg, im in england matey so its not worth the shipping costs.
i already have the larger pulley so i should be running 175 ish, thing is if i fit the 165-170 bhp engine along with the pulley i may be seeing 195 which is a very cheap way of getting 20 extra horses considering the other options.
if i fit the original dizzy, ecu etc will i still see these gains?
if so surely its well worth it?
mart1975
Postby mart1975 » Thu Dec 14, 2006 11:31 am
ok so looks like in order to achieve this im going to need to use all the electrics with the new engine.
i just need to know how to wire this in or get a copy of both engine wiring diagrams so i can work it out, anyone have these?
mart1975
Postby big_boy » Thu Dec 14, 2006 5:09 pm
just take the looms as well they both go in to the car harness useing the same plug & pins so u just swap motor with ecu & loom then plug the new motor`s loom in to the car`s harness
big_boy
