4agze crank pully question- URGENT
Postby themaleman » Tue Dec 05, 2006 8:52 am
can some please tell me wat idler pully they replace there standard one with when they put the 172mm (big) supercharger pully on. i need 2 know wat engine the replacement pully is off so i can buy 1. thanks
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby bluemaumau » Tue Dec 05, 2006 9:07 am
im just using a cambelt pulley/tensioner, got mine fom evil si
Postby themaleman » Tue Dec 05, 2006 2:04 pm
im awaiting his reply
4agte ae92 Levin
a15 powered sj410
themaleman
Postby CAMB01 » Tue Dec 05, 2006 4:08 pm
Mines from evil_si and is a tensioner bearing with an alloy outer pressed onto it.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Pelo » Tue Dec 05, 2006 6:21 pm
I use a timing belt tensioner from a SOHC mazda/ford fwd FE engine. Can't find the part number at the moment but you can get it from repco pretty cheap. You will need some washers to space it from the bracket
Pelo
Postby themaleman » Wed Dec 06, 2006 8:35 am
sweet cheers guys. and have a merry merry christmass
4agte ae92 Levin
a15 powered sj410
themaleman
