HELP!!!!!! engine wont start
Postby CAMB01 » Sun Dec 10, 2006 5:29 pm
Have you checked to see you havnt accidently knocked off any airlines?
Like maybe the airline for the map sensor, sounds like the motor is in limp mode.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby flat_0ut » Sun Dec 10, 2006 5:29 pm
I got water in mine once after steam cleaning it and it was extremely hard to drive for the first half n hour or so as well as some warning lights were on. I was told to just keep driving carefully until it dried out. Voila it dried out and was perfect. I think your stressing prematurely yet, chances are it'll be sweet
flat_0ut
Postby andyae85 » Sun Dec 10, 2006 5:33 pm
sorry im dumb as wheres the map sensor :oops: ill go check now
andyae85
Postby bluemaumau » Sun Dec 10, 2006 6:27 pm
map senor is the air sensor on the intake, it depends what gen 4age you have tho?
Postby groupagt4 » Sun Dec 10, 2006 6:32 pm
just keep it ideling for a while same happend with my car took about 3 days of ideling and driving a bit to completely dry it out
groupagt4
Postby CAMB01 » Sun Dec 10, 2006 6:34 pm
it'll be on the firewall
CAMB01
Postby sergei » Sun Dec 10, 2006 7:08 pm
check if there is no water inside the distributor cap (if you have one)...
Postby crispy'86 » Sun Dec 10, 2006 7:52 pm
best thing is to remove the distributor cap, dry it or let it dry, unplug the electrical connectors to everything and let them dry.
crispy'86
