Funny sounds from front of car
Postby ollieboy » Tue Dec 12, 2006 10:17 pm
Today I noticed my car makes funny sounds when on full lock on rough ground. Its sort of a metal on metal graunching noise. Its probably been like that for a while, I only noticed it today because I rarely have wheels at full lock.
What should I check first? Its definitely coming from front.
ollieboy
Re: Funny sounds from front of car
Postby RS13 » Tue Dec 12, 2006 10:25 pm
ollieboy wrote:Today I noticed my car makes funny sounds when on full lock on rough ground. Its sort of a metal on metal graunching noise. Its probably been like that for a while, I only noticed it today because I rarely have wheels at full lock.
You sir, are no driftah! :wink:
Need more info about the car?
RS13
Postby ollieboy » Tue Dec 12, 2006 10:33 pm
tt140 corona with 2t. I dont know about drifting but getting sideways I like. :P What else you want to know? Has a brown interior, every tyre is a different tread pattern and brand to the other tyres. :P
ollieboy
Postby RS13 » Tue Dec 12, 2006 10:42 pm
I would check the tyres/inner guards/steering/suspension/brake callipers for rub marks first, but it sounds like one of those random things again, that are pretty difficult to diagnose on the net.. perhaps if you can't see anything obvious, I would take to the local garage and get them to check it out.
RS13
Postby ollieboy » Tue Dec 12, 2006 10:48 pm
Yeah my cars got lots of those random things lol. I'll have a look tomorrow.
ollieboy
Postby crispy'86 » Tue Dec 12, 2006 11:11 pm
maybe tyre rubbing on lower suspension arm or backing plate
crispy'86
Postby big_boy » Wed Dec 13, 2006 9:28 am
could also be loose wheel nuts
or are you trying to make your P/S do more than its capable of by going to hard on lock ???????
big_boy
Postby Toymota » Wed Dec 13, 2006 11:36 am
I've also been having a weird sound with my power steering on my ST185.
Previously the air control valve on my pump was busted and the engine would usually stall on full lock. Bought a second hand valve and slapped that on and now the steering seems good but I get this loud screech as I get to full lock. I'm quite sure that I bleed the P/S system so I can't figure out what is it. The screech is only for a moment and sound almost like a belt slipping but louder.
Is this in any way similar to your problem ollieboy?
Toymota
Postby Jason T » Wed Dec 13, 2006 12:01 pm
There is a nut on the back of hub stops wheel turning to far put some grease were this nut hits on lower arm and no more noise.
Fixing Toyota's since '87
Jason T
Postby ollieboy » Wed Dec 13, 2006 12:11 pm
Nah, I don't have powersteering :(
I'll try what Jason T says and get back to ya!
ollieboy
Postby Mr Revhead » Wed Dec 13, 2006 12:34 pm
yup my $$4 is with jason ts suggestion
hiluxs etc are also bad for it
Postby fangsport » Wed Dec 13, 2006 7:40 pm
Mr Revhead wrote:yup my $$4 is with jason ts suggestion
and hiace vans.
if it isn't that, you must have worn bushes on your TCA or castor bar, allowing metal to metal contact.
fangsport
Postby ollieboy » Wed Dec 13, 2006 8:55 pm
Thankyou, that seems to have fixed it. Happy time! :D
ollieboy
