Which cars came with a 5 link F series rear?
Postby RomanV » Tue Dec 12, 2006 11:59 pm
As above.
I want to get a 5 link F series rear end for the Carina. I've heard they come in RA60 Celicas, (And bolt straight up, if from that celica) but I dont think I've ever seen one of these before, or seen them being wrecked, etc.
Are there any other cars that come with this setup? Are they hard to find? etc?
Any help appreciated.
Postby KE20 » Wed Dec 13, 2006 9:43 am
corona. rt132, i had 2 of them 5 years ago. good luck tho, the cars i got them from werent in the toyota computer, for what they had, they said they think it was sputh affrican. the diffs were even disc rear. otherwise a van for drum rear.
hiace are 5 link, 'g'
Garage Dori
current cars; , 2JZGE-YN57R Hilux double cab, Ipsum Sport, 1948 Ford F1
prevous cars; JZX81 X2, LX80, , 1JZGTE-JZX81, KE20-3SGTE, KE35-4AGE, KE35-3A, KE30, KE36, TE71, AE85, AE86, KE70 X4, KE20, 1JZGE-VVTI-JZX100, GX90, CT170, VW(beetle) x 5,(Kombi) x 2, mazdas x heaps, +more
KE20
Postby Hachiroku » Wed Dec 13, 2006 3:24 pm
RA60s have a T series live axle. There was one of those RT132 Coronas on Trademe a year or two ago, 18RGEU, W50, LSD. I'm pretty sure some Crowns come with a 5 stud coil sprung F series live axle... Doubt it would bolt in though :(
Hachiroku
Postby Snoozin » Wed Dec 13, 2006 4:36 pm
I know where there is an RA63 Celica with an F series rear end, unsure if it's IRS or not however.
Snoozin
Postby Hachiroku » Wed Dec 13, 2006 4:57 pm
Yep they're IRS unfortunately. Same as TA63, some AA63 etc.
Hachiroku
Postby c2888 » Thu Dec 14, 2006 10:57 pm
TA64 500 built for rally homogolation, good luck on that :P
1st gen celica-supra MA45, rare as rocking horse poo in aus
YR22 tarago, this should be plentiful in nz, wider, mounts are all wrong, but it is 5 link f series
probably lots of the ACE family of toyotas too
ms112 in aus got f series, 5 stud, discs, mounts are all wrong again
Dan
c2888
Postby iainous » Fri Dec 15, 2006 9:39 am
I'm wrecking a crown MS112, it has F series disc rear end, make an offer if youre keen
iainous
