AE92 GTZ gearbox/ ae101, how do i tell the difference
Postby crispy'86 » Sun Dec 17, 2006 8:22 pm
Surely someone should FAQ this, or start a post for it.
I looked at a couple of gearboxes from GTZ levins , before you say it i have clutch plate and input is definitely GZE as it's really thick, and i saw on further looking and measuring that the 2 boxes are different.
**On one box the distance from bellhousing to end casing is 410mm and the end housing is made of alloy like the rest of the box.
** The other box measures 365mm and has black metal end housing. Also the casing is thicker on the alloy end housing (195mm) than the black end housing box (170).
Can anyone shed some light into whether they are definitely GTZ boxes??
crispy'86
Postby CAMB01 » Sun Dec 17, 2006 8:40 pm
My gearbox has a black metal casing on the back of it and its a GTZ gearbox, with an LSD.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby bluemaumau » Sun Dec 17, 2006 8:41 pm
i have a ae101 and early ae92 e series boxes, and yes only the ae101 has the black on the end. the ae92 box is about 5 cm longer and obviously the plugs are different
Postby crispy'86 » Sun Dec 17, 2006 8:44 pm
Hm now i was thinking to myself it's probably an ae101 with the black end casing. And are they definitely the boxes with lsd?? Because i know it may be worn etc etc but it doesn't have the hex running through the axle shaft housing to indicate it would be
crispy'86
Postby CAMB01 » Sun Dec 17, 2006 8:49 pm
Mine cant be an ae101 as its in my ae92 FX, and ive heard ae101 gtz boxes wont go in an ae92 wothout driveshaft modifications. and my driveshafts are completely normal.
CAMB01
Postby bluemaumau » Sun Dec 17, 2006 8:58 pm
you need the ae101 shafts as they go in furthur (into the box)
Postby Bazda » Sun Dec 17, 2006 10:12 pm
the ae101 box will have an electronic speedo sensor, not a mechanical, thats the easiest way to tell.
Postby bluemaumau » Sun Dec 17, 2006 10:14 pm
winner^
Postby crispy'86 » Mon Dec 18, 2006 12:08 pm
Bazda wrote:the ae101 box will have an electronic speedo sensor, not a mechanical, thats the easiest way to tell.
That's a bit hard when the two boxes don't have the speedo sensor in them
crispy'86
Postby Bazda » Mon Dec 18, 2006 5:27 pm
ok look down where the shafts go in, the ae101 box should have a hexagon shaft through the middle and the ae92 box you will beable to see straight through with no hex bar.
Postby crispy'86 » Mon Dec 18, 2006 5:52 pm
No, had a look at weekend and they both don't have the hex through them so the ae101 box mustn't be lsd
crispy'86
Postby Bazda » Mon Dec 18, 2006 5:59 pm
nope it wont be an ae101 box.
Postby crispy'86 » Tue Dec 19, 2006 12:45 pm
Bazda wrote:nope it wont be an ae101 box.
Okay so i read in asnother post some are lsd and some aren't?? Whay would there be one box with alloy end case and the other metal and that one thinner???
crispy'86
Postby IH8TEC » Tue Dec 19, 2006 3:44 pm
the material of the 5th gear cover part of the case does not mean anything. my non lsd gbox had the alloy one, so did barry's ae101 lsd box.
as for thickness, the mr2 lsd box i put in my car seemed to be bigger, and heavier, and turned out to have thicker gears in it than the ae92 box.
Postby crispy'86 » Tue Dec 19, 2006 9:28 pm
maybe difference between early and late boxes??
crispy'86
Postby Bazda » Tue Dec 19, 2006 10:12 pm
every ae101 gtz box i've seen has had the hex bar through the middle, and every ae92 box there is no bar.
Postby crispy'86 » Tue Dec 19, 2006 10:17 pm
Bazda wrote:every ae101 gtz box i've seen has had the hex bar through the middle, and every ae92 box there is no bar.
That's handy to know then. I suspected the 101 boxes had the hex, as for ratios they should all be same in ae92 gtz's and even if the boxes are diferent thicknesses axle length going to be a problem if say someone got the shorter length box zand used normal gtz axle shafts
crispy'86
Postby Bazda » Tue Dec 19, 2006 10:31 pm
both the ae92 and ae101 gtz boxes are the same physical size, its only the aw11 supercharged box thats got a slightly bigger housing and diff gear ratios to the fwd boxes.
Postby crispy'86 » Tue Dec 19, 2006 10:33 pm
Bazda wrote:both the ae92 and ae101 gtz boxes are the same physical size, its only the aw11 supercharged box thats got a slightly bigger housing and diff gear ratios to the fwd boxes.
Hmmm, you have the ratios for the aw11 and ae92 s/c boxes?? and pics to determine?
crispy'86
Postby Bazda » Tue Dec 19, 2006 10:42 pm
i can have pics later on but ratios are here:
1st
2nd
3rd
4th
5th
final
AW11 Mr2 s/c
3.32
1.91
1.26
0.92
0.73
4.29
can also giv u the speed differences in both boxes with any size tyre u want :D
gtz levin
3.21
2.04
1.33
0.97
0.82
3.94
