5k running problems
5k running problems
Postby scope » Mon Dec 18, 2006 9:36 am
hey
just got my 5k in my ke36 but have run into problems
it runs but runs real rough. i have done the timing to tdc, when it revs it revs real smooth like it's all fine but if i keep my foot down to keep it running then it sounds like it's missing and everything. also it is very hard to get it to rev when it's under 3000rpm
it has a mild cam but i don't know the specs of it or if this will affect anything
it also used to turn over extremely slow but then my starter motor blow up so i'm assuming that was the starter motors problem not anything to do with the engine
thanks for any help
chicken fillet and bacon with everything except onion and bbq, ranch and southwest sauces
current ride: 1980 mazda rx7 series 1
previous rides: ke36 corolla, series 1 rx7, ke30 corolla, ke70 corolla x2
scope
Re: 5k running problems
Postby big_boy » Mon Dec 18, 2006 4:06 pm
scope wrote:it runs but runs real rough. i have done the timing to tdc
um try about 8 dec from memory or they might be 10 but there deffently not 0 dec
big_boy
Postby scope » Mon Dec 18, 2006 7:59 pm
i tried that also, no luck. just the same
scope
Postby big_boy » Mon Dec 18, 2006 10:31 pm
you are useing a timeing light @ idle ant you
big_boy
Postby Toymota » Tue Dec 19, 2006 12:29 am
I had a similar problem with my ST185. The engine would free rev smoothly but as soon as I put load on the engine it ran like crap, in fact, it sounded just like a WRX. The engine barely produced any power when it was misfiring like that so it was rather difficult to drive and smoke from engine bay and exhaust. However if I kept the engine at higher revs like above 3000 it would run ok.
It was suggested to me that it was the spark plugs so I replaced them and the car ran nicely again for about 30km then it started to crap out and eventually went back to how it was.
Anyway, after further inspection I noticed there was a big air leak in the breather pipe from rocker cover. Also the rocker cover itself was leaking oil. The end of the air control valve (on P/S pump) that connects to the pipe going to the intake manifold was broken off. So basically I had 2 vacuum leaks in the intake system, one before the turbo and one after.
So I fixed all of these problems plus cleaned up the spark plugs (as they were fouled) and I've done over 150km of problem free (except for a minor idling problem) driving since.
It might be as simple as a vacuum leak so carefully inspect the engine for them. They can be very sneaky as in my case on the P/S pump. Also check how you spark plugs are doing.
Sorry for telling my life story but I just thought it was necessary
Toymota
Postby scope » Tue Dec 19, 2006 9:06 am
big_boy wrote:you are useing a timeing light @ idle ant you
i can't get it to idle, won't stay alive under 3000rpm (i know this from using the choke and trying to leave my foot on the gas)
and to the other post, yeah i changed spark plugs as well. and i blocked up some vacuum lines off the intake manifold as well. i didn't do the one ontop of the tappet cover as i'm pretty sure you can still run the car fine with it open
correct me if i'm wrong?
scope
Postby big_boy » Tue Dec 19, 2006 9:21 am
you can but its not best to but you need the one with the PCV valve conected
im starting to think by what your saying its in fact a air leak not a timeing problam
id be checking float level & that the jets ant blocked also the idle mixture
big_boy
Postby ollieboy » Tue Dec 19, 2006 7:38 pm
My car did exactly as you described the other day although I'm not sure if it helps, have you checked tappets?
ollieboy
Postby scope » Wed Dec 20, 2006 9:01 am
i haven't felt the need to check them ?
scope
Postby big_boy » Wed Dec 20, 2006 4:25 pm
it wouldent hert if there tight it will miss
big_boy
Postby ollieboy » Wed Dec 20, 2006 10:04 pm
Yeah I didn't feel the need to check em either but felt like a right dick when that was the only problem and I was going. "Nah it won't be them!"
ollieboy
Postby 79rolla » Wed Dec 20, 2006 11:07 pm
sounds to e like an air leak cheake the inlet manifold is bolted on tight ect
im kinda in the middle of the same problem
idolds fast with choke on and dies when trying to idol without it
sound fimilier?
past: AE82 FXGT
79rolla
Postby ollieboy » Wed Dec 20, 2006 11:46 pm
^^^Check the idle stop solenoid. Just unplug the wire to it and if it idles that would be your problem.
ollieboy
Postby Rob » Sun Dec 24, 2006 11:02 am
Yeah if you've had the inlet manifold off then did you change the gasket?
If you block the breather on the rocker cover it will pressurise the rank case and it will stall.
Try running your timing at 15deg BTDC, thats where I used to run mine with a bigger cam.
Also try the idle screw 2 turns out for a start.
1990 ST185H - project
1996 VS Acclaim wagon
Rob
