AE92 GTZ gearbox/ ae101, how do i tell the difference
Postby escortman » Tue Dec 19, 2006 11:04 pm
will a ae101 lsd box and shafts fit into ae82?
4x4 toyota blizzard offroader
escortman
Postby Bazda » Wed Dec 20, 2006 6:53 am
escortman wrote:will a ae101 lsd box and shafts fit into ae82?
yes but u will need to run a gtz clutch and flywheel, unless you get the 4age clutch plate resplined.
Postby crispy'86 » Fri Dec 22, 2006 10:58 am
Bazda wrote:i can have pics later on
Have you got pics so i can determine if i may by some fluke have an aw11 box?
crispy'86
Postby Mr Revhead » Fri Dec 22, 2006 12:19 pm
thats easy, dont need pics
aw11 has shifters on the opposite size from FWD
Postby TRD_ZERO » Sat Dec 23, 2006 10:49 am
What does the electric speedo sensor look like compared to the mechanical one? So i know what im looking for.
TRD_ZERO
Postby bluemaumau » Sat Dec 23, 2006 10:51 am
one has a plug one has a screw on cable
Postby TRD_ZERO » Sat Dec 23, 2006 3:58 pm
Are the two sensors interchangable? Like if i took the electro one off my c56 grearbox and put it on my ae92 gtz box
TRD_ZERO
Postby bluemaumau » Sat Dec 23, 2006 10:11 pm
you need e series sensors for e series boxes and c series sensors for c series boxes, trust me, been there done that!
Postby TRD_ZERO » Sun Dec 24, 2006 11:04 am
so the one off my c seires wont fit the e series ill have to get a e series sensor if i want to run it?
TRD_ZERO
Postby crispy'86 » Sun Dec 24, 2006 12:13 pm
bluemaumau wrote:you need e series sensors for e series boxes and c series sensors for c series boxes, trust me, been there done that!
That's what the man said :D
crispy'86
Postby bluemaumau » Sun Dec 24, 2006 5:36 pm
:roll:
ncea eh
Postby crispy'86 » Thu May 10, 2007 10:59 pm
after thinking and checking all my other boxes, late model ae92's and ae101's all have the hex bar through the middle of them to determine if it's lsd or not.
What about if your ae92 box has an lsd, you can't determine if it is by turning the axles and looking through the axle holes doesn't help you any??
Strip the box down and physically check it?
crispy'86
crispy'86
