tuning Dellortos
tuning Dellortos
Postby ke25sr » Fri Dec 22, 2006 2:21 pm
I got some brand new Rekitted Dellortos.
im just wanting to now how other people have set theres up. Im sure some 1 on here must have some set uop good on a 2tgeu
I am also looking for some 32 or 34 mm chokes/venturies to fit in them at a later date.
ke25sr
Postby fangsport » Fri Dec 22, 2006 6:20 pm
here's a simple, but effective baseline jetting programme
http://hometown.aol.com/dvandrews/dellorto.htm
he has a wealth of useful info on his site regarding tuning and tricks. well worth the read.
fangsport
Postby ke25sr » Fri Dec 22, 2006 6:49 pm
Yes ive read this.
great info.
My 2t is runnig out of go at 6000 rpm. Im thinking my .10 Emulsion tube is to lean (its the leanest tube from what i can find out)
So im looking for some .1 or .6's
Dont you run carbs on your TE71 fangspor?t
ke25sr
Postby atmosports » Fri Dec 22, 2006 8:11 pm
Not down your way but if you talk to either Autoquip or Hi Tech Motorsport in Auckland they should be able to sort you out with jets/tubes/chokes etc, although in saying that Dellorto stuff is harder to get than Weber stuff.
atmosports
Postby fangsport » Fri Dec 22, 2006 9:37 pm
ke25sr wrote:So im looking for some .1 or .6's
i may have some .1 spare, but due to availability, i won't let go of the .6's.
i was running 40DHLA's on the 2TG when it was on the car, but it dropped a valve and is now in the shed awaiting re-birth.
i'm using a 40/40 DFAV Weber at the moment on the 3T, gets into it from idle. am rebuilding the sidedraft set-up with better linkages, will have it in use in the new year.
fangsport
Postby ke25sr » Sat Dec 23, 2006 10:39 am
Ild love to be able to borrow your Tubes to see if they will solve the issue.
i no of a couple of people i can get them off but there expwnsive and i dont want to have to keep buying sets untill i find the right setup.
I still got some pistons here for you to man..
Ill send them up to you.
I hadent forgot im just lazy.
ke25sr
Postby fangsport » Sat Dec 23, 2006 12:19 pm
ke25sr wrote:Ild love to be able to borrow your Tubes to see if they will solve the issue.
are you heading away over the break? might be down your way at some stage, will give you a ring if i do.
fangsport
Postby ke25sr » Sat Dec 23, 2006 8:16 pm
Im away from the 29th to the 4th or 5th. But do call when down.
0274602730
03 4536609
ke25sr
