Oil Pressure and Water Temperature
Postby SpeedRacer » Fri Dec 22, 2006 9:45 pm
Hey just so I dont kill everything, what oil pressure and water temperature should my 4AGTE have at idle and at running.
Sinister Sleeper 35
SpeedRacer
Postby IH8TEC » Fri Dec 22, 2006 10:55 pm
oil pressure on idle, i'm getting 25-30psi, but my oil is going through braided line, a thermostat, oil cooler, and filter, and getting oil pressure just before the line where my turbo feed comes from, then back to block.
and when giving it to it, between 70-80psi
haven't hooked my water temp up yet, everything is there, just not the guage, otherwise i'd tell you
Postby SpeedRacer » Fri Dec 22, 2006 11:07 pm
so bout 40-50ish psi isnt too high? give it a kick and it goes up to bout 80ish psi
Sinister Sleeper 35
SpeedRacer
Postby Lloyd » Fri Dec 22, 2006 11:12 pm
Depends on hot and cold temps for oil pressure also. Up to about 80psi when running and cold, probably 40ish at idle when cold. Hot pressures likely to be 60 and 20ish
Postby IH8TEC » Fri Dec 22, 2006 11:42 pm
when my oil is cold it's 80psi tap throttle goes to 85-90
when hot it goes down to 25-30 idle, and 65 cruising along the motorway, and 75-80 giving it to it up high.
type of oil will dictate pressure as well, i run 20w-50
Users browsing this forum: Bing [Bot], Google [Bot] and 20 guests
