4, 5 stud conversion/ offset
Postby bluemaumau » Mon Dec 18, 2006 9:10 pm
im looking for some 15/16 inch race wheels for my car which is currently 4x100,
i like some of the standard honda rims and all evo wheels, 4x114.3 and 5x 114.3
which toyotas come with 4x114.3 and 5x114.3? (fwd)
any one know of any straight bolt ons>?
also say i was going to buy some 15s and some 18s, would i get the same offset on each set (offset noob question)
Postby bluemaumau » Wed Dec 20, 2006 10:28 pm
any 4x114.3 fwd toyotas? or 5x114.3 that bolt up to ae's?
Postby bluemaumau » Wed Dec 20, 2006 10:33 pm
okay so ive done some reaerch and camry, curren, non gt4 celica hubs look to be the goods. does anyone know if they bolt up.?
Postby KE20 » Mon Dec 25, 2006 8:40 am
camery, curren and celica are 5x100, the 5x114.3 are the rwd toyotas. like supra, chaser, hilux, hiace, but the newer cars are designed totake a fwd stylr offset wheel. you want to measure how far out the wheel and stick and workit out from there the offset of the wheels you want.
also for the offset, it depends on the width as the offset is the hub mounting face from the centre of the rim. so if you had 18" wheels that were and say 8" wide and some 15" that were 7" wide, for them to stick out the same, the 18" would have to have an offset 1/2"more to be the same, ie" 15x7 +25, and 18x8+37.5.
Garage Dori
current cars; , 2JZGE-YN57R Hilux double cab, Ipsum Sport, 1948 Ford F1
prevous cars; JZX81 X2, LX80, , 1JZGTE-JZX81, KE20-3SGTE, KE35-4AGE, KE35-3A, KE30, KE36, TE71, AE85, AE86, KE70 X4, KE20, 1JZGE-VVTI-JZX100, GX90, CT170, VW(beetle) x 5,(Kombi) x 2, mazdas x heaps, +more
KE20
