is my alternator naffed?
Postby matt dunn » Sun Dec 24, 2006 10:18 pm
NZ_AE86 wrote:
SpeedRacer wrote:4ages are internally reged?
Most are. ;)
Only Externally regulated 4AGE's are the ones that are a conversion and still use a 4K, 3A etc alternator,
and the AW11 4AGZE's are also external, and very rare, and have very expensive special regulators.
And voltage while cranking will tell you stuff all, as depens on the type of starter, battery type, and compression.
Matt
Postby RED TOP MR 2 » Tue Dec 26, 2006 5:55 pm
with cleaning copper termanals that have oxidized you drop them in a cup of boiling water with a teaspoon of baking soda.they come out nice.my car wouldnt start on 12.4 because the battery had blown a cell i forgot that.marshal batteries ran some tests they were real helpful.
RED TOP MR 2
Postby Bling » Fri Dec 29, 2006 1:16 am
SpeedRacer wrote:ok took alternator in and auto aprky tested it and said it was fine, so now will see if it lasts a long drive to make sure its not my bad wiring :S
I took mine to an auto sparky, he tested it and said it was fine. However he also said, that he cant guarantee it is actually fine, as the test he did using some machine, doesnt always show up a naffed alternator...
how did you get on, what progress have you made?
