Couple of q's from a newbie Toyo owner...
Postby chingching » Mon Dec 25, 2006 11:43 am
Kia ora gang. Just a couple of q's.
1) Just bought a 2nd hand '88 Levin. On the dash I've just noticed an indicator that stays on that looks like an orange/yellow aerial view of a wire model car with the rear lights flashing. What da hell does that mean? (Didn't come with owner's manual).
2) Anybody know where I can pick up the 18R repair manual. Have tried searching web but no dice so far. Am working on an old ute I dug outta da boonies and it's got an 18RGU Celica motor with Mikuni/Solex carbies (from what I can make out).
Thanks for listening to the new guy babble on.
ching
Don't put off till tomorrow that which you can do today.
chingching
Postby Alex B » Mon Dec 25, 2006 11:59 am
1 Means you got a tail light out i think.
Postby chingching » Mon Dec 25, 2006 3:29 pm
Thanks pyro.
chingching
Postby solitaire » Mon Dec 25, 2006 10:59 pm
My Light does that at random.... i aggree its the tail lights but the only thing wrong with my tail lights that i can see is the high stop LED's in the spoiler... 25% dont work... maybe a bulb is causing an irregular voltage?
AE92, KZJ120, KDJ120
solitaire
Postby Mr.Phreak » Tue Dec 26, 2006 10:40 am
Most LED hi stops aren't included in tail light warnings. If all your lights are still going, then it's most likely a wrong wattage bulb, or corrosion in the socket (excluding monkied wiring etc)
Mr.Phreak
Postby chingching » Tue Dec 26, 2006 8:41 pm
Thanks for the replies and possible remedies bruthas.
ching
chingching
Postby fangsport » Tue Dec 26, 2006 10:33 pm
1. chances are the filament in the taillight bulb above the exhaust has broken. very common.
2. havn't got an 18RG manual, but do have Mikuni /Solex inspection /rebuild information.
fangsport
Postby chingching » Fri Dec 29, 2006 9:36 am
fangsport wrote:1. chances are the filament in the taillight bulb above the exhaust has broken. very common.
Yeah fang, somebody else mentioned the same thing about the bulb itself so will look at it at some stage. But I'll definitely keep you in mind regarding the Mikunis once the ute gets closer to completion.
ching
chingching
