Whats good about FXGT
Postby BWDOWN » Wed Jan 03, 2007 8:32 pm
Hey guys,
I'm looking at buying a cheap daily driver, (shock horror) its a toyota FXGT. I think the 87 to 90/1 shape is AE92 its 4AGE but not 20V.
Its got a fair few options TEMS, Cruise control, Auto H/lights etc
Tidy as condition and no rust, are these good reliable cars and what problems should I look out for?
TIA
B20vtec Allmotor 90% of the way to 170wkw Thanks to 0800 cartune 41.co.nz & Spec Performance
My Profile
BWDOWN
Postby 86_rolla » Thu Jan 04, 2007 9:07 am
rust
Current: EF Honda civic
Ex cars: 2E corolla
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1488
86_rolla
Postby Leon » Thu Jan 04, 2007 9:50 am
Yep, everything except the glass and the tyres is prone to rust.
Other than that, make sure it's not smoking badly, and that it isn't using large amounts of oil or water.
Other than that, you can mostly run them into the ground and they come back asking for more.
You've listed lots of electrical doodads, and generally the more of those, the more likely they are to crap out, so check everything works.
Postby Chelles » Thu Jan 04, 2007 11:12 am
I've got an AE92 '87 FXGT and she is a gem and for a 20 year old car I'm well impressed. A tiny bit of rust but it is 'Toyota Tough' ... if you service it well, it will look after you. The other thing I like is when it does need parts they are cheap second hand and plentiful! :)
'96 RS Mirage Race car... (and when I'm a good girl; EVO 1!!) 2014 Toyota Hilux - daily driver!!
Gone but not forgotten: Race car AE85.6 Levin, AE101 Trueno, 84 MR2 AW11, 94 MR2 SW20, SR coupe KE35, AE92 FXGT, AE91 FXZS...
Chelles
TS Original Member
Postby Mr Revhead » Thu Jan 04, 2007 11:16 am
the ae92 doesnt rust anywhere near as bad as the ae82.
as mentioned cheaps are cheap and easy, only thing getting tricky to get is lights!
Postby Leon » Thu Jan 04, 2007 11:56 am
Mr Revhead wrote:the ae92 doesnt rust anywhere near as bad as the ae82.
This is very true, though I have seen a few with rusty hatch's and lower doors. So it is worth a close look, as that can get expensive fast.
Postby BWDOWN » Thu Jan 04, 2007 5:04 pm
cheers guys, thanks for the tips :)
My Profile
BWDOWN
Postby gmacrae » Fri Jan 05, 2007 10:50 am
you wont go wrong with one of those cars man, my 87 fxgt is probably the best car i've ever owned. Go thru it with a fine tooth comb and strip/touch up any rust spots and maintain it well and it'll look after you - make sure you service that auto trans.
gmacrae
