smallport head, bigport block
Postby Cakky » Tue Jan 09, 2007 3:30 pm
will this work? would any adaption be needed or is it a straight bolt? what happens with the tvis off my old bigport head?
did search but only found something the other way around...
Cakky
Postby Leon » Tue Jan 09, 2007 3:38 pm
You'll want the smallport intake to go with the smallport head...
Postby Cakky » Tue Jan 09, 2007 5:51 pm
in terms of ecu etc will the ecu react badly to this? i'm assuming the bigport ecu,loom will still work?
Cakky
Postby ee904age » Thu Jan 11, 2007 9:40 am
Not 100% sure but I would suggest using the smallport ECU & loom, considering the majority of sensors etc are on the head eg: dist, injectors, no tvis and so on.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
