c50 and c52 gearbox shifter
Postby Caveman » Tue Jan 09, 2007 5:15 pm
Hi
Right ive got a c50 from an aw11. Ive also got a c52 from a levin. I want to use the c52 in the aw11. Is it possible to use the c50 gearbox housing with the shifter on it already in the right position and just put the c52 internals in it? Or should I just mess around with my c52 to swap the shifter onto the other side.
Thanks
AW11 Track Toy
Formerly known as 1998
Caveman
Postby HELBND » Tue Jan 09, 2007 5:20 pm
http://www.padandwheels.com/mr2/blackto ... 3/c56.html
there you go, some info on modifying the C52 to fit, if it helps
HELBND
Postby AceSniper » Tue Jan 09, 2007 6:59 pm
if you pull them apart you will end up with two shafts with all the gears on you should be able to swap them between the housings
AceSniper
Postby Caveman » Wed Jan 10, 2007 3:02 pm
Thanks guys
I think ill drill the hole like ben said, also good to know that all the parts are interchangable, makes finding an lsd easier 8)
AW11 Track Toy
Caveman
Postby bluemaumau » Wed Jan 10, 2007 6:01 pm
dude theres been a brand new lsd on tardme for ages only fits c series, was a good price if i recall correctly
Postby HELBND » Wed Jan 10, 2007 7:00 pm
bluemaumau wrote:dude theres been a brand new lsd on tardme for ages only fits c series, was a good price if i recall correctly
the one thats starting at 800? he wants a fair bit more for it iirc
HELBND
Postby Caveman » Wed Jan 10, 2007 7:02 pm
will thanks for the heads up
brand new from mr toyota is $1200, I dont know if revhead can do a better deal 8)
FYI i changed the shifter location on the c52, was really easy, all I did was follow the instructions on the website.
AW11 Track Toy
Caveman
Postby bluemaumau » Wed Jan 10, 2007 8:21 pm
yea i thinmk thats the one, lol i thought it was 300. knew i was wrong :lol:
Postby TRD_ZERO » Wed Jan 10, 2007 9:13 pm
damn $300 got me all excited for a second
TRD_ZERO
Postby bluemaumau » Wed Jan 10, 2007 9:15 pm
yea its c series tho
Postby TRD_ZERO » Wed Jan 10, 2007 9:19 pm
i got both
TRD_ZERO
Users browsing this forum: Bing [Bot], Google [Bot] and 19 guests
