Toyota Rota? Hey it rhymes :)
Postby DriftSpecStarlet » Thu Jan 18, 2007 10:26 pm
Ive got this new thing called the Toyota Rota :)
2E-ELU 1295cc Engine Fuel Injected
Its idling at 1.5 grand and sumtimes it pulses from 1 - 1.5grand...
Ive dubbed it "The Slow Rota"
I have cleaned the TB and checked the Throttle Cables all tight and what not,
all i can think of is that the Sensor mite be had it?
Anyone help me out it would be real nice,
and is there a way to Manually lower my Idle cause we aint all loving a high revvin engine at the lights :P especially with no exhaust on at the moment,
Cheers Ben.
Toyota Celica ST185
Big f'n front mount,
Bodykit (actually looks decent)
Lowerd on blue Springs
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Location: Gisborne, New Zealand, Earth, Universe, Milky Way.
Postby l1ttle_d3vil » Thu Jan 18, 2007 11:13 pm
could be your throttle position sensor or map sensor, they're the only sensors I can think of that would cause it. but i would be looking for vacuum leaks, or a faulty auxilary bypass valve first...
Postby spencer » Thu Jan 18, 2007 11:20 pm
lower the idle with the screw on your throttle body. and shouldnt the milky way come before the universe in your location
ms63 crown
spencer
Postby DriftSpecStarlet » Thu Jan 18, 2007 11:22 pm
Lol cheers for the Idle help, and yerr ill look into it aye... Might be Faulty Bypass or could be the Sensor but how am i going to test the Sensor :S
HAHAHA Yerr bro probably i was just bein a Gumby
Toyota Celica ST185
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Postby big_boy » Thu Jan 18, 2007 11:23 pm
or the ISC valve
big_boy
Postby DriftSpecStarlet » Fri Jan 19, 2007 12:06 am
ISC?
Toyota Celica ST185
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Postby big_boy » Fri Jan 19, 2007 12:10 am
idle speed control valve
big_boy
Postby DriftSpecStarlet » Fri Jan 19, 2007 12:13 am
Ahh, where abouts is this Valve?
Toyota Celica ST185
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Postby big_boy » Fri Jan 19, 2007 12:18 am
im not sure on your engin or if you evan have one some bace models dont but if uyou do its near your TPS normally
big_boy
Postby DriftSpecStarlet » Fri Jan 19, 2007 9:36 am
[img][img]http://img78.imageshack.us/img78/2494/tbandmanifoldwiththevalzj2.th.jpg[/img][/img]
Hmm dus that work lol? new at this image thing... is it the thing ontop of the TB with the Screw in it and it has a pipe going to another valve with a adjustable bolt?
Toyota Celica ST185
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Postby big_boy » Fri Jan 19, 2007 10:13 am
it looks like whats doing the idle juob but its unlike any ISC or idle up solind that if ever seen
have you checked have you checked for a vacume leake esspecly in that line going to it
also what happens if you take the vac line away from it
big_boy
Postby DriftSpecStarlet » Fri Jan 19, 2007 10:24 am
Okay i tightened the Bolt ontop of the TB and its brought its idle down to about 900 when hot, 1500 when cold, but the need seems to bump around... like its not a smooth clean idle its rough and moves around -50/+50 rpm
Toyota Celica ST185
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Ohh yerr took off that Vac Line and it didnt do a thing??
Toyota Celica ST185
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Postby big_boy » Fri Jan 19, 2007 10:28 am
for that much movement id be starting with vac lines & then looking at giveing the TPS a good clean first
for sale EE90
big_boy
Postby DriftSpecStarlet » Fri Jan 19, 2007 10:33 am
Or get a new Engine :) Coz this things not givin me enuff torque steer :) Hey thanks for the help man really appreciated!
Toyota Celica ST185
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Postby big_boy » Fri Jan 19, 2007 10:34 am
dam you & being so far away other wise id take your old one of your hands
for sale EE90
big_boy
Postby DriftSpecStarlet » Fri Jan 19, 2007 11:29 am
Yeah that dus suck coz i dont want it.... will be stripping it down for Ornaments :)
Toyota Celica ST185
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Postby Vertigo » Sat Jan 20, 2007 11:38 am
maybe theres something wrong with your drift spec forum name?
TVIS just kicked in, yo!
Vertigo
Postby Paulio » Sun Jan 21, 2007 4:08 pm
your car is an absolute sack of shit and needs to be shot. bloody noise polution.
Paulio
Postby slammed_integral » Mon Jan 22, 2007 10:28 pm
how do you get to the throttle position sensor to "clean" it on 4efte gt starlet?
http://www.cardomain.com/id/slick_ep
there is nothing sour cola worms cant fix...
slammed_integral
