4agze flywheel bolts
Postby flygt4 » Mon Jan 22, 2007 3:29 pm
apparently there is a specified torque setting for 4agze flywheel bolts. i dont think tis really that important but anyone know what it is?
i might just humour toyota and use their chosen settings seeing as i have a torque wrench lying around. :wink:
either that or ill put a bit of loctite on the threads and do it up just tight enuf :D
flygt4
Postby sergei » Mon Jan 22, 2007 4:14 pm
You will find those settings are tight, somewhere between 80 and 120Nm (can't remember exactly)...
Postby Jason T » Mon Jan 22, 2007 4:54 pm
74nm.
Why?? ARP flywheel bolts for 7M are same part number as 4AG
Fixing Toyota's since '87
Jason T
Postby IH8TEC » Mon Jan 22, 2007 5:02 pm
i did mine up to 80ft lbs, which is 108nm
Postby CAMB01 » Mon Jan 22, 2007 8:08 pm
IH8TEC wrote:i did mine up to 80ft lbs, which is 108nm
The problem with over tightening bolts like that, is that they stretch and are under alot of stress, and can break or lose clamping pressure.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby bluemaumau » Mon Jan 22, 2007 8:13 pm
if its the same as 4age bolts its
74nm/54 lbf ft
Postby CAMB01 » Mon Jan 22, 2007 8:16 pm
There all the same for the 16 valve 4age/ze. 54ft/lbs
CAMB01
Postby big_boy » Mon Jan 22, 2007 10:51 pm
just do it up intill it breaks & then back the next 1 off 1/4 of a turn
for sale EE90
big_boy
Postby IH8TEC » Mon Jan 22, 2007 11:05 pm
it was a while ago, it was definately at least 60-65ft lbs its not a hell of alot when you look at the makeup of the bolt, and the size. and yes i do know all about over tightening :wink:
