starter motor problems - 20v/k50
Postby Meadzy » Tue Jan 23, 2007 9:19 pm
hey all
im running 20v silvertop on a k50 box with 212 mm clutch setup and the 20v starter motor seems to be giving me a bit of grief as of late, it has been starting fine untill last nite where it sounds like its not pushing out far enough or too far? when i go to turn it on it sounds like its grinding and it doesnt seem to start.
anyone know whats wrong and if it would be better to use some other type of 4age starter motor??
thanks
hayden
"Keeping it true to the JDM"
J-Spec Group
http://jspecgroup.com/forums/index.php
AE86,200sx,EG6
Meadzy
Postby Dell'Orto » Tue Jan 23, 2007 9:25 pm
Maybe the bearings are starting to get worn? The brushes oughtnt make a grinding noise.
You're bloody keen running a K50 behind a 20v!
Postby Meadzy » Tue Jan 23, 2007 9:34 pm
yer im keen alrite hopefully itl last a while, um ok will have a look into replacing the bearings.. should it work alright though with this starter motor and this setup?
J-Spec Group
AE86,200sx,EG6
Meadzy
